| Chad911sc |
Apr 25 2025, 05:50 PM
Member ![]() ![]() Group: Members Posts: 243 Joined: 24-September 24 From: Florida Member No.: 28,374 Region Association: South East States |
So after 5 long months of work, I finally have the 2056 built and installed. (IMG:style_emoticons/default/piratenanner.gif)
I have a couple questions about the 123 4RV distributor. I haven’t hooked it up to power yet, but from my understanding, you hook up only the red wire and then power the ignition and a light should come on in the body of the distributor. 1) Since our motors go in a CW direction, the first movement of the distributor goes clockwise until the light turns off? Then CCW until the green light comes on? Correct? 2) The engine has dual carb Webber 40’s/Web cam 86a/Mild port and polished stock valve heads. My question is what setting should I use on the distributor? From what I see it looks like curve #3. Does this sound right? 3) Do I use the vacuum port on the distributor body to the base of one of my carbs, or do I plug it off, or do I leave it open? Thanks in advance for any info! Attached thumbnail(s) |
| emerygt350 |
Apr 30 2025, 06:08 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,423 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I would look up the coil if nobody chimes in on this. Did the 123 and the coil come with the motor? If you are unsure you may want to check the primary resistance. Here is what 123ignition says...
"For 4 cylinder engines you could use the original coil or other coils with a primary resistance of at least 1.0 Ohm. For standard street engines we advise a “Bosch Blue” or “Beru ZS106” coil. For high rpm engines a “Bosch red (0 221 119 030)” or “Beru ZS109” is much better." |
Chad911sc New engine finally in! Apr 25 2025, 05:50 PM
Front yard mechanic I was told to use 5 seems to run great Apr 25 2025, 07:03 PM
Cairo94507 Wow! That looks amazing. :beer2: Apr 26 2025, 06:30 AM
Chad911sc Thanks for the replies fellas!
Hadn’t even l... Apr 27 2025, 06:42 AM
moto914 Looks like a lot of good work. Apr 27 2025, 07:44 AM
sb914 Very tidy looking. Apr 27 2025, 08:19 AM
technicalninja Curve 3 looks fine for an initial setting to me.
... Apr 27 2025, 08:54 AM
emerygt350
... Apr 27 2025, 09:49 AM
emerygt350 dupe Apr 27 2025, 09:49 AM
Chad911sc Yeah 3 is what I read on a couple other sites as w... Apr 27 2025, 07:48 PM
Chad911sc Oh yeah…and is there any thought on the vacuum a... Apr 27 2025, 07:52 PM
emerygt350 I have run it with and without. Many with the 123... Apr 28 2025, 04:35 AM
emerygt350 And is that a ballast resistor near the coil? Apr 28 2025, 04:37 AM
Shivers Nice job, that’s a beauty! Apr 28 2025, 05:59 AM
Spoke Looks fantastic. Apr 28 2025, 12:28 PM
technicalninja Vacuum advance is helpful for street. Will improve... Apr 28 2025, 12:44 PM
friethmiller Your engine bay is the "Tits!" Nice... Apr 28 2025, 01:54 PM
emerygt350 I think you may be thinking of the Bluetooth versi... Apr 28 2025, 02:50 PM
Chad911sc Ok….im just going to plug it off for now and onc... Apr 28 2025, 09:33 PM
emerygt350 The Bosch coils had it built in so no ballast was ... Apr 29 2025, 04:57 AM
Superhawk996
The Bosch coils had it built in so no ballast was... May 1 2025, 06:40 AM
GBX0073 Wow Great Job !!! Apr 29 2025, 10:39 AM
Root_Werks Really clean install, looks good!
:driving: Apr 29 2025, 12:40 PM
Chad911sc Working on the Stainless Exhaust today, still need... Apr 30 2025, 05:22 AM
worn
Working on the Stainless Exhaust today, still nee... Apr 30 2025, 05:33 PM
Chad911sc Thanks again for all the wonderful compliments... May 1 2025, 06:31 AM
Chad911sc Pics of the exhaust…it being mated up to the MSD... May 1 2025, 06:35 AM
bajafreaks
Pics of the exhaust…it being mated up to the MS... May 1 2025, 08:36 AM
Chad911sc Yes the Pertronix coil already has 3.0 ohms of res... May 1 2025, 07:39 AM
Chad911sc The header is super beefy and very well built for ... May 1 2025, 09:29 AM
bajafreaks
The header is super beefy and very well built for... May 1 2025, 09:54 AM
Chad911sc Yes I built it custom for my application.
It take... May 1 2025, 08:14 PM
bajafreaks
It tak... May 2 2025, 07:39 AM
Tonyooc Very clean install, nice job. May 4 2025, 09:09 AM![]() ![]() |
Lo-Fi Version | Time is now: 14th December 2025 - 12:29 PM |
