> New engine finally in!, 123 distributor 4RV
Chad911sc
post Apr 25 2025, 05:50 PM
So after 5 long months of work, I finally have the 2056 built and installed. (IMG:style_emoticons/default/piratenanner.gif)
I have a couple questions about the 123 4RV distributor. I haven’t hooked it up to power yet, but from my understanding, you hook up only the red wire and then power the ignition and a light should come on in the body of the distributor.
1) Since our motors go in a CW direction, the first movement of the distributor goes clockwise until the light turns off? Then CCW until the green light comes on? Correct?
2) The engine has dual carb Webber 40’s/Web cam 86a/Mild port and polished stock valve heads. My question is what setting should I use on the distributor? From what I see it looks like curve #3. Does this sound right?
3) Do I use the vacuum port on the distributor body to the base of one of my carbs, or do I plug it off, or do I leave it open?
Thanks in advance for any info!
emerygt350
post Apr 29 2025, 04:57 AM
The Bosch coils had it built in so no ballast was necessary. Perhaps your coil does not have that. I don't think it hurts to have it. Others will know more than I.
Superhawk996
post May 1 2025, 06:40 AM
QUOTE(emerygt350 @ Apr 29 2025, 06:57 AM) *
Excess resistance in the coil primary reduces spark intensity.
Measure the coil primary resistance to determine if the coil has a built in ballast resistor or not. Follow whatever 123 has a recommendation for minimum resistance as noted above by EmeryGT350
Chad911sc   New engine finally in!   Apr 25 2025, 05:50 PM
Front yard mechanic   I was told to use 5 seems to run great   Apr 25 2025, 07:03 PM
Cairo94507   Wow! That looks amazing. :beer2:   Apr 26 2025, 06:30 AM
Chad911sc   Thanks for the replies fellas! Hadn’t even l...   Apr 27 2025, 06:42 AM
moto914   Looks like a lot of good work.   Apr 27 2025, 07:44 AM
sb914   Very tidy looking.   Apr 27 2025, 08:19 AM
technicalninja   Curve 3 looks fine for an initial setting to me. ...   Apr 27 2025, 08:54 AM
emerygt350   Curve 3 looks fine for an initial setting to me. ...   Apr 27 2025, 09:49 AM
emerygt350   dupe   Apr 27 2025, 09:49 AM
Chad911sc   Yeah 3 is what I read on a couple other sites as w...   Apr 27 2025, 07:48 PM
Chad911sc   Oh yeah…and is there any thought on the vacuum a...   Apr 27 2025, 07:52 PM
emerygt350   I have run it with and without. Many with the 123...   Apr 28 2025, 04:35 AM
emerygt350   And is that a ballast resistor near the coil?   Apr 28 2025, 04:37 AM
Shivers   Nice job, that’s a beauty!   Apr 28 2025, 05:59 AM
Spoke   Looks fantastic.   Apr 28 2025, 12:28 PM
technicalninja   Vacuum advance is helpful for street. Will improve...   Apr 28 2025, 12:44 PM
friethmiller   Your engine bay is the "Tits!" Nice...   Apr 28 2025, 01:54 PM
emerygt350   I think you may be thinking of the Bluetooth versi...   Apr 28 2025, 02:50 PM
Chad911sc   Ok….im just going to plug it off for now and onc...   Apr 28 2025, 09:33 PM
emerygt350   The Bosch coils had it built in so no ballast was ...   Apr 29 2025, 04:57 AM
Superhawk996   The Bosch coils had it built in so no ballast was...   May 1 2025, 06:40 AM
GBX0073   Wow Great Job !!!   Apr 29 2025, 10:39 AM
Root_Werks   Really clean install, looks good! :driving:   Apr 29 2025, 12:40 PM
Chad911sc   Working on the Stainless Exhaust today, still need...   Apr 30 2025, 05:22 AM
worn   Working on the Stainless Exhaust today, still nee...   Apr 30 2025, 05:33 PM
emerygt350   I would look up the coil if nobody chimes in on th...   Apr 30 2025, 06:08 AM
Chad911sc   Thanks again for all the wonderful compliments...   May 1 2025, 06:31 AM
Chad911sc   Pics of the exhaust…it being mated up to the MSD...   May 1 2025, 06:35 AM
bajafreaks   Pics of the exhaust…it being mated up to the MS...   May 1 2025, 08:36 AM
Chad911sc   Yes the Pertronix coil already has 3.0 ohms of res...   May 1 2025, 07:39 AM
Chad911sc   The header is super beefy and very well built for ...   May 1 2025, 09:29 AM
bajafreaks   The header is super beefy and very well built for...   May 1 2025, 09:54 AM
Chad911sc   Yes I built it custom for my application. It take...   May 1 2025, 08:14 PM
bajafreaks   Yes I built it custom for my application. It tak...   May 2 2025, 07:39 AM
Tonyooc   Very clean install, nice job.   May 4 2025, 09:09 AM
- Lo-Fi Version Time is now: 14th December 2025 - 12:30 PM
