What do I do now? Stripped allen screw, All ideas appreciated |
Porsche Rescue |
Feb 5 2005, 04:51 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
Started to change shift bushings at trans (side shift). Discovered that the allen set screw is stripped and will not hold the 4mm wrench. It is also flush with the "cup" so I can't get vice grips on it.
Here's the best idea I can come up with: Try to drill it out. I would like to move the whole shift console to the bench for the operation. Can I remove the two nuts (drain tranny first?) and take it and the rear shift rod to the bench/drill press? Or do I have to remove the roll pin on the shift lever to get the shift console off the tranny? All help greatly appreciated. |
Joe Ricard |
Feb 6 2005, 07:23 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Yes two 13mm nuts and the housing drops right out of the case. Yes be careful of how it comes out so it goes back in the same way. I need to do this to mine also but I'll nurse it till I get back in that area again.
Oh yea drain the transaxle 1st. |
Lo-Fi Version | Time is now: 7th June 2024 - 09:38 PM |
