> Directional switch return to off, New switch - still not returning
North Coast Jim
post Dec 2 2017, 01:38 PM
Changed out both the Directional switch and the Wiper switch in the 914 a week or so ago. Seems to be working fine EXCEPT - the wiper return to off capability still doesn't work.
I have the following steering wheel, part number 914-347-8041, a hard plastic phenolic ?? wheel with the following return post, see pics. Seems the return post isn't long enough to mate with the switch mechanism. Is it broken off or is there another part I should be looking for ??
I've scoured the World for previous posts on this subject to no avail. Or maybe I'm still a rooking at looking
Thanks all
Attached ImageAttached Image
914sgofast2
post Jul 12 2025, 02:57 PM
I had the same problem when replacing the turn signal switch on my 1970 car with an aftermarket switch assembly from Dansk. Finally I had to shim the operating arm screwed to the bottom of the steering wheel hub with 3 flat washers (1 washer under each of the attaching screws) to make the tab portion stick down far enough into the turn signal switch in order to move the little arm up or down when the turn signal arm was moved, and thereby turn off the blinkers. I also agree that that the 4 mounting screws which hold the turn signal switch must not be screwed on too tightly, and don't forget to use the small metal tubular spacers on those 4 screws where they pass through the turn signal switch.
North Coast Jim   Directional switch return to off   Dec 2 2017, 01:38 PM
JamesM   Buy about 20 turn signal switches from as many dif...   Dec 3 2017, 12:31 AM
76-914   PM Mark Heard "914SIXER". He scours the ...   Dec 3 2017, 08:25 AM
mzalanka   I have dealt with this same issue. It shouldn’t ...   Dec 3 2017, 12:32 PM
North Coast Jim   I have dealt with this same issue. It shouldn’t...   Dec 3 2017, 01:12 PM
mzalanka   Ok good. You’ve ruled out a problem with the swi...   Dec 3 2017, 01:27 PM
SirAndy   the wiper return to off capability still doesn...   Dec 3 2017, 01:23 PM
North Coast Jim   [quote name='North Coast Jim' post='2554193' date...   Dec 3 2017, 03:02 PM
North Coast Jim   [quote name='North Coast Jim' post='2554193' date...   Dec 3 2017, 04:08 PM
mm911   [quote name='North Coast Jim' post='2554193' date...   Jul 12 2025, 11:28 AM
Hans Jan   :popcorn:   Dec 3 2017, 04:22 PM
Valy   Is the canceling tab on the steering wheel mounted...   Dec 3 2017, 10:54 PM
Jonathan Livesay   Is the canceling tab on the steering wheel mounte...   Dec 4 2017, 10:43 AM
barefoot   Is the canceling tab on the steering wheel mount...   Jul 11 2025, 05:23 PM
North Coast Jim   Thanks all for the valuable input. Will try these ...   Dec 6 2017, 10:30 AM
jim_hoyland   PM sent Need to find out how you finally fixed it   Apr 25 2025, 07:08 PM
jim_hoyland   Is the Dansk TS switch known to not cancel ?   Jul 11 2025, 04:44 PM
914sgofast2   I had the same problem when replacing the turn sig...   Jul 12 2025, 02:57 PM
jim_hoyland   Thanks, good tips :) Were there supposed to be 4 ...   Jul 12 2025, 03:34 PM
914sgofast2   No washers under the switch. I was referring to th...   Jul 13 2025, 02:17 PM
- Lo-Fi Version Time is now: 14th December 2025 - 12:18 PM
