Bright light, bright light!, whoa, these babies are awesome! |
red914 |
Feb 7 2005, 12:11 AM
...i believe in coyotes and time as an abstract... Group: Members Posts: 862 Joined: 8-February 04 From: poulsbo, washington Member No.: 1,641 |
installed my pilots today; got 'em with the fancy bracket from Craig at CAMP 914. so i am now a happy camper!
needed to call my tech support ("dino, are you sure the electrons are in there? i don't see any... you're saying if i hook these wires together the electrons will get into the lights?" (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) ), and all is well. eventually the wiring will be changed so that i can run drivers only, just like the kewl kids! let's see, SS brackets from Craig (along with other stuff last year), pedal board from Engman, wheel from Brad Meyeur, brake kits from Perry Kiehl, carbs from Andyrew (all teenagers should have a V8 914), calipers from Dan Root, too much stuff to mention from Kevin Powers and Dino Davis. heck, i have even gotten help from the good guys at Triad NW! for those of you who have not done business with any of the above mentioned men, you should co it if you need stuff. Thanks, dudes! (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) btw, Aaron; i didn't put a relay on mine, and they seem to work fine. nothing odd happened when i kicked 'em on. if i find out anything more or notice anything strange, i'll pass it on. |
Reiche |
Feb 7 2005, 03:22 AM
Member Group: Members Posts: 169 Joined: 13-October 04 From: Vista, CA Member No.: 2,934 |
Late model ('75 & 76) rectangular fogs were 55w H3. So you were both right.
Relays can also help head/foglights burn brighter. You can run bigger wires to the relays to make sure you are getting maximum current and hence full brightness. Trying to run lots of current through too-small wires creates heat. Bad. Even if you don't smell anything burning, the heat could cause the insulation to crack eventually. Scott may be right about anything up to 55w being ok, but the wiring in these cars is at least thirty years old and was only just sufficient when new. I would run relays period. |
Lo-Fi Version | Time is now: 6th June 2024 - 03:37 AM |
