> Adjusting Valves, What method is correct?
Artfrombama
post Sep 10 2025, 10:53 PM
Artfrombama
Adjusted the valves using the TDC method with satisfactory results but I find it somewhat difficult and takes too long.
The way I’ve always adjusted valves is with a remote starter button and bumping the starter. When the exhaust open, adjust the intake. Then when the intake fully open and starting to close, adjust the exhaust. EOIC
Is either correct? (IMG:style_emoticons/default/WTF.gif) If not please explain.
emerygt350
post Sep 11 2025, 05:16 AM
I like the crusty method. Put it in fifth, roll the wheel till a valve of choice is completely compressed (or use the starter, but I think the wheel is easier). Then adjust the opposite valve. So if you compress the exhaust valve on cylinder 4 you would adjust the exhaust valve on cylinder 2.
No TDC, no hoping it is as loose as it can be, no losing track of where you are or have been.
Kansas 914
post Sep 11 2025, 05:24 AM
QUOTE(emerygt350 @ Sep 11 2025, 05:16 AM) *
From the Cap'n: http://www.914world.com/bbs2/index.php?showtopic=28758
Artfrombama   Adjusting Valves   Sep 10 2025, 10:53 PM
emerygt350   I like the crusty method. Put it in fifth, roll t...   Sep 11 2025, 05:16 AM
Kansas 914   I like the crusty method. Put it in fifth, roll ...   Sep 11 2025, 05:24 AM
VaccaRabite   The way I’ve always adjusted valves is with a r...   Sep 11 2025, 05:44 AM
GregAmy   Cap'n method, both valve covers off, remote st...   Sep 11 2025, 07:42 AM
Superhawk996   Nothing wrong with the Capt’n method but it need...   Sep 11 2025, 08:07 AM
emerygt350   I don't even bother with the 'fast way...   Sep 11 2025, 08:26 AM
930cabman   just had a look at the wise words of the Cap, look...   Sep 11 2025, 10:08 AM
ctc911ctc   I spent a good deal of time analyzing Krusty's...   Sep 11 2025, 01:25 PM
Literati914   The simplest way that I've found and IMHO, for...   Sep 12 2025, 08:12 AM
Artfrombama   Thanks to everyone that responded. I'm wishi...   Sep 12 2025, 12:09 PM
Dave_Darling   I think I will continue to use the EOIC method, m...   Sep 13 2025, 09:57 PM
rfinegan   I'm of the school like emerygt350, we know the...   Sep 13 2025, 07:11 AM
neyen14   With one wheel off the ground and the car in 5th, ...   May 6 2026, 09:53 AM
VaccaRabite   With one wheel off the ground and the car in 5th,...   May 6 2026, 11:03 AM
neyen14   With one wheel off the ground and the car in 5th...   May 6 2026, 11:36 AM
FlacaProductions   Is the e-brake on?   May 6 2026, 10:16 AM
neyen14   Is the e-brake on? Sadly.... no   May 6 2026, 10:22 AM
friethmiller   Is the e-brake on? Sadly.... no If the car is ...   May 6 2026, 11:04 AM
Dave_Darling   "Slight gear"? "Total gear"? ...   May 6 2026, 01:43 PM
9 User(s) are reading this topic (6 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th May 2026 - 03:55 PM
