| Ron914 |
Oct 22 2025, 12:16 PM
Member ![]() ![]() Group: Members Posts: 429 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California
This is the original muffler from my car . I was wondering if it can be saved/fixed.
Not sure if this will be required to pass smog on my 1976 as it is part of the original equipment needed to pass as a 49 state car in California . I currently have the repaired Bursch I got from Franz @drem914 installed on my car but not sure if this will be a problem when I go for my smog test ? 436] Attached thumbnail(s) |
| Jack Standz |
Oct 23 2025, 12:46 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 575 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
I have a similar question about an original muffler with a small hole in it, about 1/4 in diameter. Believing the internal corrosion is a greater area than that hole, and wanting to both keep the muff and do a good job, I wonder if a good welder can not just weld on a surface patch, but actually cut in a butt welded patch and grind it down flush to look and function like no damage ever occurred. Anyone with experience with this technique, any drawbacks? Will a muffler shop do this or does it require a more skilled welder? Have repaired/welded a stock 2 liter muffler with a rust hole (like the one in the photo). Yes, it wasn't so easy. But, a good welder with the right settings and patience should be able to fix it. But, if the rust is extensive, the bandaid may have limited life. The problem is the metal is thin and you can easily have blowouts. Used a mig welder, but next time might try TIG. Attached thumbnail(s) |
Ron914 Original muffler Oct 22 2025, 12:16 PM
Jack Standz Yes. But, welding on thin rusty metal is not easy... Oct 22 2025, 02:43 PM
Ron914
Yes. But, welding on thin rusty metal is not eas... Oct 22 2025, 05:36 PM
burton73 Ron,
You should go for your smog with the cat on. ... Oct 22 2025, 06:27 PM
Ron914
Ron,
You should go for your smog with the cat on.... Oct 22 2025, 07:44 PM
sixnotfour California is special... Oct 22 2025, 07:51 PM
Ron914
I have one other card ... Oct 22 2025, 10:57 PM
wonkipop
[quote name='sixnotfour' post='3229499' date='Oct... Oct 23 2025, 01:20 AM
JeffBowlsby I have a similar question about an original muffle... Oct 22 2025, 10:53 PM
Ron914
I have a similar question about an original muff... Oct 23 2025, 08:46 AM
JeffBowlsby ^^^this. Oct 23 2025, 07:24 AM
Lockwodo I've seen a lot of California smog tests over ... Oct 23 2025, 08:01 AM
Jack Standz
[quote name='Jack Standz' post='3229527' date='Oc... Oct 23 2025, 11:37 AM![]() ![]() |
Lo-Fi Version | Time is now: 24th October 2025 - 02:52 AM |
