| Literati914 |
Aug 26 2024, 01:42 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,312 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I’m gonna pick one of these up and was wondering if anyone here has tried one? My only concern is the depth of the socket part itself.. could be a little short?
| Literati914 |
Oct 30 2025, 08:49 AM
.. There seems to be some part of the cylinder head that snags on the socket preventing it from sliding all the way down over the plug. I guess I need a thinner walled socket .. Is that not a temperature sensor wire/ring sitting under the #3 plug (they are usually under #3 when used), that's fouling your socket? - yeah a thin stock type socket would probably be helpful in that case. |
Literati914 Spark Plug Wrench Aug 26 2024, 01:42 PM
windforfun Scale the drawing.
:beer3: :beer3: :beer3: Aug 26 2024, 01:45 PM
Literati914
Scale the drawing.
I mean.. I only have 3rd gra... Aug 26 2024, 01:58 PM
windforfun
Scale the drawing.
I mean.. I only have 3rd gr... Aug 26 2024, 02:09 PM
ClayPerrine If you want one, I will give you mine.
And I ... Aug 26 2024, 02:13 PM
Literati914
[quote name='windforfun' post='3163976' date='Aug... Aug 26 2024, 02:14 PM
Literati914
And I... Aug 26 2024, 02:16 PM
Geezer914 Just use a socket and extension, you should be tor... Aug 26 2024, 02:19 PM
McTyke
Just use a socket and extension, you should be to... Oct 28 2025, 08:33 AM
VaccaRabite
The spark plug socket I have, which is from a Ka... Oct 30 2025, 05:26 AM
Shivers You have to be GI Joe with the Kung Fu grip to use... Aug 26 2024, 02:28 PM
worn
I’m gonna pick one of these up and was wonderin... Aug 26 2024, 02:39 PM
Literati914
Just use a socket and extension, you should be to... Aug 26 2024, 02:45 PM
Literati914
It is sort of like the factory part. I like the ... Aug 26 2024, 02:50 PM
worn
It is sort of like the factory part. I like the... Aug 26 2024, 07:34 PM
914sgofast2 That wrench looks like junk designed by someone wh... Aug 26 2024, 03:47 PM
windforfun
That wrench looks like junk designed by someone w... Aug 26 2024, 04:36 PM
Literati914
That wrench looks like junk designed by someone w... Aug 26 2024, 03:58 PM
Geezer914 Like I said, if you are using a torque wrench to t... Aug 26 2024, 04:45 PM
Superhawk996 Not sure that spring-a-ma-thing is going to clear ... Aug 26 2024, 04:59 PM
Literati914
[quote name='914sgofast2' post='3164014' date='Au... Aug 26 2024, 05:14 PM
Literati914
Not sure that spring-a-ma-thing is going to clear... Aug 26 2024, 05:18 PM
Shivers
@Literati914
They can stick, any place where ... Aug 26 2024, 06:43 PM
bkrantz And make triple sure the wrench will retain a lose... Aug 26 2024, 07:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 02:42 AM |
