> Progressive VS Linear Rate Springs, ed ju cate me....
Aaron Cox
post Feb 8 2005, 11:58 PM
Professional Lawn Dart
i have opinions of both.....
i run linear 140's..... a friend of mine has progressive 165's.
what are the pros and cons of each.
bondo
post Feb 9 2005, 12:48 AM
QUOTE (Mueller @ Feb 8 2005, 11:39 PM)
QUOTE (Aaron Cox @ Feb 8 2005, 11:16 PM)
QUOTE (MattR @ Feb 8 2005, 11:15 PM)
you have a sway bar, right?  a big ass tarret one.  That is most definatly not a linear progression.
its a torsion bar..... thats all it is.... effective spring rate doesnt change....
and i have no body roll (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
the swaybar does act as a spring and it does affect the ride of the vehicle....unless you drive on perfectly smooth roads so that both sides of the bar travel up and down at the same time....being in the real world, that is not the case (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
the rate of the swaybar does change corner to corner and changes with the differential of wheel movement from side to side....a bar set on firm is going to have a worse ride than a bar set on soft........
The rate also changes based on how far the sway bar "arm" is from horizontal. If you're twisting the bar such that it's 45 degrees from horizontal (I know, it'd never be that much, this is just an extreme example) then it'll be at a different rate than when the arms are horizontal.
Aaron Cox   Progressive VS Linear Rate Springs   Feb 8 2005, 11:58 PM
MattR   im not your friend   Feb 9 2005, 12:01 AM
rick 918-S     Feb 9 2005, 12:04 AM
MattR   http://www.914world.com/bbs...   Feb 9 2005, 12:04 AM
nebreitling   do you like your spring rates -- and therefore han...   Feb 9 2005, 12:07 AM
Aaron Cox   but the exponential curve of the spring rate isnt ...   Feb 9 2005, 12:07 AM
MattR   Well dont your forces increase as the tire patch i...   Feb 9 2005, 12:08 AM
Aaron Cox   body roll with progressive springs in exponential....   Feb 9 2005, 12:13 AM
MattR   you have a sway bar, right? a big ass tarret one....   Feb 9 2005, 12:15 AM
nebreitling   i don't know how much all this exponential vs....   Feb 9 2005, 12:16 AM
Aaron Cox     Feb 9 2005, 12:16 AM
Brett W   Progressive rate springs are springs that get stif...   Feb 9 2005, 12:16 AM
JOHNMAN   My opinion about the progressive coil springs is t...   Feb 9 2005, 12:19 AM
lapuwali   Pretty much, that's it. You can run a softer ...   Feb 9 2005, 12:20 AM
MattR   Squishy for production cars? Cars create oscillat...   Feb 9 2005, 12:21 AM
lapuwali   <...   Feb 9 2005, 12:27 AM
Aaron Cox   for street: gimme progressives..... nice ride for...   Feb 9 2005, 12:28 AM
Aaron Cox   ...   Feb 9 2005, 12:39 AM
bondo     Feb 9 2005, 12:48 AM
trekkor     Feb 9 2005, 12:49 AM
nebreitling     Feb 9 2005, 12:53 AM
trekkor   O.K., This is really wierd ht...   Feb 9 2005, 01:02 AM
SirAndy   ...   Feb 9 2005, 01:22 AM
redshift   I must have installed my progressive springs upsid...   Feb 9 2005, 01:49 AM
Marv's3.6six   One of the more recent trends in damper technology...   Feb 9 2005, 04:26 AM
ArtechnikA     Feb 9 2005, 05:58 AM
trekkor
  Feb 9 2005, 09:22 AM
trekkor   REALLY flat... http://www.914world...   Feb 9 2005, 09:26 AM
TimT
  Feb 9 2005, 09:46 AM
Mueller   Hey Tim, are cars with tender springs considered ...   Feb 9 2005, 10:08 AM
Aaron Cox   since i have dialed in more swaybar trekkor   Feb 9 2005, 12:07 PM
TimT
  Feb 9 2005, 01:35 PM
groot   I believe many racers use linear rates springs bec...   Feb 9 2005, 02:11 PM
- Lo-Fi Version Time is now: 16th June 2024 - 09:09 PM
