| potomacmidget |
Jan 1 2026, 03:06 PM
I gotta have more cowbell.... ![]() ![]() Group: Members Posts: 168 Joined: 27-March 11 From: Maryland Member No.: 12,860 Region Association: North East States
Happy New Year Everyone,
I am trying to do a bit of a refresh on my 1971, D-Jet stock car, (new vacuum hoses, valve adjustment, etc.) and I would like to pull out my AAR valve and inspect it closely (or replace with a known good one I have) but I am fearful on how to disconnect the AAR wire to the white wire. Its encased in what looks to be stock plastic rectangular wire cover, but figured I would ask for advice before I do any damage. Thanks in advance. Best, Reg |
| Literati914 |
Jan 16 2026, 09:42 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,204 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
.. Make sure that wire is well insulated. It supplies full time 12v sourced from the fuel pump fuse. A short to ground will kill power to your fuel pump and/or melt wiring depending on the size fuse you have installed on the relay board. Curious, think an issue there would most likely always 'cause a popped fuse or could it be an intermittent thing as well? |
potomacmidget AAR valve wiring connection - how do I disconnect? Jan 1 2026, 03:06 PM
pbanders
I am trying to do a bit... Jan 1 2026, 03:11 PM
potomacmidget
I am trying to do a bi... Jan 1 2026, 03:26 PM
fixer34
[quote name='pbanders' post='3239096' date='Jan 1... Jan 1 2026, 03:40 PM
fixer34 Here's a picture of a 3-way, but same idea. C... Jan 1 2026, 03:48 PM
potomacmidget Thanks so much! I appreciate it.
Best,
Reg Jan 1 2026, 04:20 PM
robkammer Oddly enough, I pulled my AAR this morning, that c... Jan 9 2026, 01:25 PM
JamesM Just a standard space connector under the plastic ... Jan 10 2026, 01:45 PM
potomacmidget
Just a standard space connector under the plastic... Jan 15 2026, 05:23 PM
rick 918-S
Just a standard space connector under the plasti... Jan 16 2026, 07:22 AM
cabrioartie I'm probably not understanding something about... Feb 18 2026, 06:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th February 2026 - 10:57 PM |
