| oakdalecurtis |
Oct 17 2025, 05:34 PM
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California
76 2.0 fi stock, 130,000 miles
Lost compression on 1 cylinder. Engine out, heads off, valve seat dropped. Shop said amazing engine hadn’t seized up. Look at pic of valve seat, they had never seen the melted look on the left side of the valve port. Any thoughts on that? Pistons had valve marks, cam was done, crank was 3 thousands out out round, bearings shot. We’re going to replace everthing other than the block (still good). New cylinders and heads, pistons, crankshaft, cam, bearings, clean the injectors, polish all the tin and anything else it might need. Engine should be like new when finished! |
| Cairo94507 |
Jan 22 2026, 06:32 PM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,621 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
Congratulations; that came together nicely. (IMG:style_emoticons/default/beerchug.gif)
oakdalecurtis Rebuild update Oct 17 2025, 05:34 PM
oakdalecurtis Update:
Engine coming together, everything new exc... Dec 16 2025, 06:36 PM
trojanhorsepower Looks good. What oil pump and heads did you use? Dec 16 2025, 06:48 PM
930cabman
Looks good. What oil pump and heads did you use?... Dec 16 2025, 07:15 PM
oakdalecurtis
Looks good. What oil pump and heads did you use?... Dec 17 2025, 05:35 AM
oakdalecurtis Btw, my engine has a Tangerine Racing oil pressure... Dec 18 2025, 11:09 AM
Root_Werks Looks good!
Did you stick with 2.0 or bump to... Dec 18 2025, 11:36 AM
oakdalecurtis
Looks good!
Did you stick with 2.0 or bump t... Dec 19 2025, 11:22 AM
oakdalecurtis Finally got it back, drives great, smoother motor.... Jan 22 2026, 05:03 PM
Root_Werks Yay! That's awesome!
You got that in... Jan 22 2026, 05:35 PM
bkrantz Nice! Now keep the cylinder heads under 1200Â... Jan 22 2026, 08:23 PM
oakdalecurtis
Nice! Now keep the cylinder heads under 1200... Jan 23 2026, 11:20 AM
oakdalecurtis
Nice! Now keep the cylinder heads under 1200... Jan 23 2026, 11:21 AM
oakdalecurtis Happy owner! My baby’s like new!
:b... Feb 7 2026, 04:22 PM
flyer86d Congratulations! Many of us wish we can be at ... Feb 7 2026, 05:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 05:27 PM |
