| martinef1963 |
Feb 11 2005, 04:39 PM
The Saga Continues... ![]() ![]() Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States |
Okay - this is my last plea for solutions before I have to drop the engine and replace the alternator on my 72 teener.
I've checked the tightness of the belt for possible slipping - and it's fine. Replaced the Voltage Regulator and still get the alternator red idiot light on my panel. The battery is shot because the alternator is not charging it. I put a jump on it and it runs fine, but when I take the cables off - it will run until the engine dies (radio won't work, and only left headlight unit will come up). (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) Is there anything that I might be missing - or is there a sure fire way of testing the alternator to identify it as the "actual perpetrator?" As usual - I value your 914 wisdom. |
| bondo |
Feb 11 2005, 05:39 PM
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Check all your connections, including ground straps. Also, a toasted battery may not take a charge so your alternator may be fine. A completely toasted battery is like an open circuit... if it's that bad then disconnecting the jumper cables while the engine is running is like disconnecting the battery, which may fry the diodes in the alternator. Moral of the story: Always test the charging system with a known good and charged battery.
martinef1963 Alternator Feb 11 2005, 04:39 PM
bd1308 same thing happened to me....VR died. Go figure. Feb 11 2005, 04:40 PM
jr91472 I am no expert here, but I do know that you do NOT... Feb 11 2005, 04:54 PM
Headrage http://www.914world.com/bbs2/h... Feb 11 2005, 05:08 PM
bd1308 whats a alternator? Just kidding, don't lync... Feb 11 2005, 05:33 PM
martinef1963 Bondo - the battery was just fine. I drove the ca... Feb 11 2005, 05:56 PM
jr91472 I am assuming you meant to say altenator????
if s... Feb 11 2005, 06:01 PM
jkeyzer <... Feb 27 2005, 08:57 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:50 AM |
