| erwindv |
Mar 18 2026, 07:33 AM
Newbie ![]() Group: Members Posts: 47 Joined: 17-June 16 From: Belgium Member No.: 20,119 Region Association: Europe |
I own a 1971 914 and lately I've been having trouble starting it.
The car only starts if I wiggle the key a bit back and forth while turning it. I also bypassed the starter switch by connecting the starter directly to the battery. So in my opinion, the problem is the ignition switch. Only issue: removing it on a 1971 model doesn’t seem to be as straightforward as described on the Pelican Parts (which covers models after 1971). Is there anyone who can point me in the right direction or provide instructions on how this should be done? Should I unbolt and remove the steering casing (see image)? Attached thumbnail(s) |
| mepstein |
Mar 18 2026, 09:59 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,549 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
This is an old but very good thread that explains how to remove the lock on an early steering column. I put my phone on the dash, followed it through step by step and had success. If I can, you can. Put a little dish on the dash to collect small parts while you do the work.
http://www.914world.com/specs/rekey.php The base piece on the lock can crack but can be jb welded/epoxied back together. |
erwindv Ignition switch removal Mar 18 2026, 07:33 AM
TheCabinetmaker What's the last 5 numbers of the vin? They cha... Mar 18 2026, 09:27 AM
TheCabinetmaker Looks like you have an early model. The key switch... Mar 18 2026, 09:36 AM![]() ![]() |
Lo-Fi Version | Time is now: 18th March 2026 - 06:49 PM |
