> Car won't start - I seem to have spark and air, was running great on 4X jackstands, lowered it, won't start
potomacmidget
post Mar 25 2026, 09:35 AM
I gotta have more cowbell....
Hi All -
So...I decided to do a bit of a refresh on my 71 D-jet car. Adjusted the valves, new points, (same condenser) new cap, rotor and a rebuilt throttle valve switch. New vacuum hoses everywhere, functioning AAR . Had the car on 4X jackstands to adjust the valves, and was running the car and setting the idle - had it all back together (oil bath air cleaner, new hoses). Was running great.
Lowered the car (removed all 4 jackstands) and now it won't start. Nothing has physically changed.
I just pulled the fuel line post fuel filter and pre-fuel pump, and fuel flowed fine. Points gap looks good, I have cranked the car with the timing light on each spark plug wire, light flashes. I don't think air is an issue, AAR wide open and boot is off throttle valve. I DON"T seem to smell fuel with all the cranking.
Did I lose the prime on my fuel pump? I have an original 3 port type installed, all new gas lines as of last March. Car was running great on jackstands, I am befuddled.
Any advice appreciated!
thanks,
Reg
emerygt350
post Mar 25 2026, 09:46 AM
I would check the fuel pressure, not smelling some fuel with all that cranking...
You could try a shot of starter fluid too. If it starts you know you have a fuel issue. Then it is pressure or the trigger points/ecu. Did you double check to make sure the trigger point wires are making a good connection?
potomacmidget
post Mar 25 2026, 10:22 AM
QUOTE(emerygt350 @ Mar 25 2026, 11:46 AM) *
Thanks! I will check the trigger points and get some starting fluid and report back. Thanks for your help, I appreciate it.
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: Montreal914
- Lo-Fi Version Time is now: 28th November 2026 - 01:34 AM
