| lexatola |
Oct 18 2014, 12:08 AM
Newbie ![]() Group: Members Posts: 10 Joined: 17-September 14 From: Woodinville, WA Member No.: 17,914 Region Association: Pacific Northwest |
I'm getting close to pulling the trigger on the 2270 engine kit from the Type 4 store. I'm curious if anyone knows what the difference between the kit and the Raby 2270 SR. I see they each have different HP specs. Do we think this is an actual difference or just a difference in written spec? Same cam? Same Heads? Curious if this kit can make better HP than 140? Headers? Other tested and ordained cam?
I'd appreciate any input based on experience, Best, Alex |
| nivekdodge |
May 21 2026, 04:42 PM
Member ![]() ![]() Group: Members Posts: 336 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region
I was suearching and found this very old post. If re written today where’s the best bang for the buck?
Kevin |
lexatola Type 4 Store 2270 Oct 18 2014, 12:08 AM
Vacca Rabite Different engines built to different specs using d... Oct 18 2014, 03:05 AM
Harpo I was not aware that they started selling engine k... Oct 18 2014, 04:23 AM
Mark Henry
I was not aware that they started selling engine ... Oct 18 2014, 07:19 AM
RobW McMark. :mcmark: Oct 18 2014, 05:48 AM
Mblizzard They are. Looking around that store is like surfi... Oct 18 2014, 06:09 AM
JStroud You are correct, the type 4 store is now owned by ... Oct 18 2014, 07:52 AM
lexatola Thanks all for the confirmation that we think the ... Oct 18 2014, 10:34 AM
Racer Chris
Thanks all for the confirmation that we think the... Oct 18 2014, 12:05 PM
type47
Seems like if you take a 2.0 add headers, twin ca... Oct 20 2014, 07:34 AM
r_towle
Thanks all for the confirmation that we think the... Oct 21 2014, 08:33 AM
McMark I find that looking at the HP numbers is just conf... Oct 18 2014, 11:25 AM
Mark Henry A header is the cheapest boost in HP and it's ... Oct 18 2014, 12:41 PM
ConeDodger
I find that looking at the HP numbers is just con... Oct 18 2014, 01:40 PM
Mikey914 Exponential power to price curve. Pick your sweet ... Oct 18 2014, 12:06 PM
Hank914 What is there for a slight bump in HP if you want ... Oct 18 2014, 01:16 PM
Mark Henry
What is there for a slight bump in HP if you want... Oct 18 2014, 01:27 PM
Hank914
What is there for a slight bump in HP if you wan... Oct 18 2014, 02:13 PM
Mark Henry
Thanks for the reply. Yes, I saw that. I shoul... Oct 18 2014, 04:38 PM
lexatola Thanks again for the continued activity. I like t... Oct 18 2014, 05:00 PM
Vacca Rabite
Thanks again for the continued activity. I like ... Oct 18 2014, 08:23 PM
76-914
Thanks again for the continued activity. I like... Oct 20 2014, 08:24 AM
r_towle
Thanks again for the continued activity. I like ... Oct 19 2014, 07:37 AM
rmdinmd
[quote name='Hank914' post='2099544... Oct 19 2014, 06:38 AM
Mark Henry
I have been thinking about adding an oil cooler ... Oct 19 2014, 09:51 AM
Racer Chris
Heat exchangers and fuel fired heaters have been ... Oct 19 2014, 06:53 PM
Jake Raby
I'm getting close to pulling the trigger on t... Oct 20 2014, 08:47 AM
KELTY360
[quote name='lexatola' post='2099298' date='Oct 1... Oct 20 2014, 06:24 PM
malcolm2
Jake did you have this car at the tail of the... Oct 22 2014, 07:05 PM
Jake Raby
Jake did you have this car at the tail of th... Oct 22 2014, 07:59 PM
r_towle Please do a thread on that car Jake....
I would lo... Oct 20 2014, 05:40 PM
Jake Raby
I would l... Oct 20 2014, 10:18 PM
lexatola Here's my Outlaw.....Just for fun! Oct 20 2014, 10:24 PM
lexatola I have to say, being brand spanking new to the 914... Oct 20 2014, 10:48 PM
McMark :rolleyes: Oct 21 2014, 01:32 AM
Dave_Darling Another factor is that the 911 and 356 performance... Oct 21 2014, 09:46 AM
SchwarzHorse And if you install an engine manufactured by anoth... Oct 21 2014, 01:25 PM
Mark Henry
And if you install an engine manufactured by anot... Oct 21 2014, 01:50 PM
DBCooper
And prepare to stop telling people that you drive... Oct 21 2014, 01:57 PM
RobW That's it. I'm joining the 924 club! Oct 21 2014, 01:58 PM
mr2by4
... Oct 21 2014, 02:25 PM
biosurfer1
... Oct 21 2014, 03:36 PM
Jake Raby People want to be "builders", but they w... Oct 21 2014, 10:56 PM
lexatola Lot's of great perspectives added to the subje... Oct 22 2014, 09:23 AM
stugray
What I'm hoping to learn, as an example, is ... Oct 22 2014, 04:30 PM
Mark Henry Unless you are stroking it stick with the stock ro... Oct 22 2014, 09:33 AM
DBCooper
Cam I like the WEB 163/86b
Absolutely. Split dur... Oct 22 2014, 05:01 PM
Vacca Rabite The "easy" builds won't get you to y... Oct 22 2014, 11:27 AM
Racer Chris 40 IDFs won't get you to 180 hp without lots o... Oct 22 2014, 01:40 PM
rhodyguy Lex, you should take the short trek to gig harbor ... Oct 22 2014, 03:44 PM
r_towle 103mm pistons and cylinders (use forged Pistons, J... Oct 22 2014, 04:52 PM
Jake Raby If torque is more important than HP, then make a c... Oct 22 2014, 06:21 PM
rdauenhauer
I have moved toward a 2.4L combo for my engine p... Oct 22 2014, 10:13 PM
Jake Raby No, the next generation combo is 82X97mm using my ... Oct 22 2014, 11:13 PM
Sfreeman615 I purchased the 2270 kit and heads from the type4 ... Oct 23 2014, 09:36 AM![]() ![]() |
Lo-Fi Version | Time is now: 21st May 2026 - 07:50 PM |
