> Project Thread - molded front glass bumper
root
post Dec 12 2004, 09:20 AM
Two Wheeled Type4 Completed!
I just finished all the major work installing a front glass bumper from 'rennsport'
on my '72. Next is the rear. I'm going to attempt to post some pics.
Here goes..... (IMG:style_emoticons/default/burnout.gif)
root
post Feb 13 2005, 09:33 PM
Did you need to flare out the metal to match the f/g lip? Mine (Bills ex) were to match the HPH flares and they weren't bonded....
Are you going to add f/g mat/cloth on the inside?
No I didn't bend the metal at the cutout edge to match the flare. The flares have about 2.5" of flat flange like area that I was able to bond to.
1. Painted both surfaces with fiber resin
2. layed down short pieces of cloth between the screw holes (otherwise the screwss twist up the cloth into a choatic ball of fiber).
3. layed down long 12" strips of cloth along the outer edge (away from the screws)
4. There's a small 'V' notch along the inside where the metal and f/g meet I have filled
that with 'cat hair' to provide more support. I'll under coat the seam at the end to resist moisture.
did you have to modify that front bumper much? I got one and it is a really bad fit. you have any suggestions?
The right front was damaged by PO years ago. I had to pull that out about 1/4" to get it to reach the end of the bumper (hydraulic jack, chains and PITA (IMG:http://www.914world.com/bbs2/html/emoticons/bootyshake.gif) )
Otherwise the fit was O.K. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Where's yours fitting poorly?? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
In general, you can make fiberglass fit where ever you like.
It's Just :
1. Messy
2. A job that requires iterative resin/cloth layups (roughing the surface) each step
3. Use of sculpting foam and/or wood pieces for curbing and bridging for small gaps if you dare!
Here's a value added benefit -
if you get enough foam and wood it maybe a floatable teener.(IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif)
root   Project Thread - molded front glass bumper   Dec 12 2004, 09:20 AM
scott thacher   my first :trophy: :ttiwwp:   Dec 12 2004, 09:22 AM
spare time toys   wow its the stealth bumper I did not know those we...   Dec 12 2004, 09:22 AM
root   Hey, what did I do wrong? :idea:   Dec 12 2004, 09:23 AM
root   checking the fit   Dec 12 2004, 09:24 AM
root   bracket I added for bolting on permanent - 'ti...   Dec 12 2004, 09:26 AM
root   I also added a knife edge aligning plate on each s...   Dec 12 2004, 09:27 AM
root   welded in the headlight web   Dec 12 2004, 09:28 AM
root   closeup up of welded web with bondo over the weld   Dec 12 2004, 09:30 AM
root   major work complete, with 'pilot' driving ...   Dec 12 2004, 09:32 AM
sgomes   Outstanding job!!! :trophy:   Dec 12 2004, 11:42 AM
neo914-6   Why bond it in? Won't it be a PITA to repair?...   Dec 12 2004, 11:50 AM
root   Here's a corner shot. As far as repair goes. S...   Dec 12 2004, 11:59 AM
rdauenhauer   Pretty clean :) Where are your horns?   Dec 12 2004, 02:09 PM
rhodyguy   nice work. don't get your fingers caught in th...   Dec 12 2004, 04:34 PM
root   I never really thought about getting my fingers ca...   Dec 12 2004, 07:49 PM
rhodyguy   HEY!!! i think i know those wheels. ...   Dec 12 2004, 08:22 PM
michel richard   The thing with the eyelashes was for any kind of m...   Dec 12 2004, 09:24 PM
root   Kevin, I really like the wheels. I'm gonna mis...   Dec 12 2004, 09:58 PM
root   fibermorphing flares http://...   Feb 12 2005, 11:10 AM
root   Marked for cutting -   Feb 12 2005, 11:12 AM
root   sheet metal screws holding it on prior to resin an...   Feb 12 2005, 11:13 AM
root   overview before I begin the permanent install -   Feb 12 2005, 11:14 AM
Air_Cooled_Nut   I'm envious of your skills. She looks great s...   Feb 12 2005, 11:42 AM
root   left flare-in-process.... 2 lines: outer line is o...   Feb 12 2005, 07:38 PM
root   15 sheet metal screws to register the flare alignm...   Feb 12 2005, 07:40 PM
root   left-side   Feb 12 2005, 07:41 PM
root   drilling a starter hole for the nibbler   Feb 12 2005, 07:42 PM
root   nibble time   Feb 12 2005, 07:43 PM
root   ready to grind off the paint around the edge note ...   Feb 12 2005, 07:45 PM
root   ground down to the metal   Feb 12 2005, 07:46 PM
root   resin - fiber - screws holding it 'till tomorr...   Feb 12 2005, 07:48 PM
BahnBrenner914   did you have to modify that front bumper much? I g...   Feb 13 2005, 02:13 AM
neo914-6   Dan, Did you need to flare out the metal to match...   Feb 13 2005, 11:10 AM
root     Feb 13 2005, 09:33 PMroot   The above pic was taken after I coarse feathered t...   Feb 13 2005, 09:36 PM
SirAndy   and when it's all done, she will look like thi...   Feb 13 2005, 09:45 PM
SirAndy   rear also molded in ...   Feb 13 2005, 09:46 PM
SirAndy   btw. i also molded in the rockers ... looks great...   Feb 13 2005, 09:48 PM
Aaron Cox   AAHHNDY i like the look of the glassed in ducky.....   Feb 13 2005, 09:48 PM
root   SirAndy, I got a pic of yours and a couple others ...   Feb 13 2005, 09:59 PM
JohnB   Nice work, the good weather we had the last few we...   Feb 14 2005, 11:13 AM
JmuRiz   Looks good, BTW where in Sterling are you, I'm...   Feb 14 2005, 11:57 AM
root   Yep! The weather is one of the main obstacles ...   Feb 14 2005, 11:57 AM
root   Sterling is my R&D business location- just North o...   Feb 14 2005, 12:03 PM
JmuRiz   Ok, I know that area, been past there many a time,...   Feb 14 2005, 01:50 PM
scooter311   Hey root looks great! Are you doing the front...   Feb 14 2005, 02:11 PM
root   Yep! Soon as I finish the rears, then I'll...   Feb 14 2005, 03:33 PM
Scott Schroeder   Hi Root - Mine was done the same way, except for t...   Feb 14 2005, 03:57 PM
Scott Schroeder   ... the funny part is that I cant wait until I hav...   Feb 14 2005, 04:02 PM
root   Yea. My plan is to keep like this 'till I sma...   Feb 14 2005, 04:18 PM
root   Scott, is the the right front corner of a red Aust...   Feb 14 2005, 04:21 PM
Scott Schroeder   Yep - a 3000 BJ-8.   Feb 14 2005, 04:32 PM
root   Scott- me and my 3rd restoration job, '58 Heal...   Feb 14 2005, 04:52 PM
root   The sun came out this weekend and I got most of th...   Mar 13 2005, 07:24 PM
root   I need some wheel and rubber to fill those flares ...   Mar 13 2005, 07:26 PM
Aaron Cox     Mar 13 2005, 08:03 PM
root   Got some more progress done on the 916 fibermorphi...   Mar 27 2005, 03:59 PM
root   REALLY NEED MORE WHEEL AND RUBBER NOW!   Mar 27 2005, 04:01 PM
Aaron Cox   need mo rubba.....lower the rear...and lose the mo...   Mar 27 2005, 04:03 PM
SirAndy     Mar 27 2005, 04:04 PM
root   Actually the Monza is bent and the cut-out is croo...   Mar 27 2005, 04:08 PM
root   Looks like it stopped raining for a couple minutes...   Mar 27 2005, 04:12 PM
Andyrew   Lookin good! Gona be doin that myself pretty s...   Mar 27 2005, 04:19 PM
jgiroux67   http://www.914world.com/bbs2/htm...   Mar 27 2005, 06:52 PM
jgiroux67   Oh ya, can you show a picture (you too Andy) of wh...   Mar 27 2005, 06:55 PM
SirAndy   i don't have any real closeups, let me know wh...   Mar 27 2005, 09:55 PM
jgiroux67   Something like this, I want to see the hood gap.   Mar 27 2005, 10:19 PM
jgiroux67   another, I dont know why that is so bad quality   Mar 27 2005, 10:20 PM
Aaron Cox   nice shoes http://www.914world.com/...   Mar 27 2005, 10:25 PM
jgiroux67   http://www.914world.com/bbs2/htm...   Mar 27 2005, 10:27 PM
Scott Schroeder   ...   Mar 28 2005, 12:45 AM
Andyrew   Make it tight with fiberglass, and grind it down t...   Mar 28 2005, 01:38 AM
- Lo-Fi Version Time is now: 8th June 2024 - 01:36 AM
