| bdstone914 |
Jul 17 2026, 10:25 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,421 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have the first prototype parts for the 914-6 style accelerator cable bracket, bell crank and linkage pull rod.
I redesigned the pull rod and bell crank. The cable support support bracket is 3D printed in stainless steel for increased strenght and rust prevension. The bell crank and pull rod use metric ball sockets wirh a safety wire clip and dust cover to prevent dirt from entering the socket. The pull rod uses two ball sockets unlike the original rod which uses a wire loop that wears. All parts will be yellow zinc plated. The bell crank is made with sloted holes to adjust the throttle modulation. The pull rod lenght is adjustable as it is a hollow tube connecting two ball sockets with all thread. The set will include an original pivot post with plastic bushings. The set requires an intermediate plate with the threaded boss for the bell crank. These were used on tail shift and 914-6 transmissions. Group buy price now is $225. It will increase to $250 when i have full production in 2-3 weeks. At this time i only have 10 accelerator brackets but can get more in about two weeks. I prefer payment by Zelle or check image. Shipping at cost by UPS ground. I used a piece of all thread in the pictures in place of an actual accelerator cable. Attached thumbnail(s) |
| roundtwo |
Jul 21 2026, 11:14 AM
Member ![]() ![]() Group: Members Posts: 372 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California
@bdstone914
Hi Bruce, I have a 1973 with side shift 3.0 liter six with PMOs. Does the kit contain everything I need to convert from the basic cable pull right to the carbs? Can you describe what this is? :"The set requires an intermediate plate with the threaded boss for the bell crank." If so, I'd like to buy the set. I can send you pics of my current set up if needed. Thanks, Todd |
| davep |
Jul 22 2026, 06:17 AM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,381 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Can you describe what this is? :"The set requires an intermediate plate with the threaded boss for the bell crank." Todd, the transmission case has 3 parts, the main case, the tail cover, and the intermediate plate. This plate has to have the threaded hole for the pivot shaft; all /6 trans have this plate, but the /4 never did. So either have the plate drilled and tapped or try to find an original. |
| bdstone914 |
Jul 22 2026, 07:12 AM
@davep
' date='Jul 22 2026, 05:17 AM' post='3265914'] [quote name='roundtwo' post='3265850' date='Jul 21 2026, 01:14 PM'] Can you describe what this is? :"The set requires an intermediate plate with the threaded boss for the bell crank." [/quote] Todd, the transmission case has 3 parts, the main case, the tail cover, and the intermediate plate. This plate has to have the threaded hole for the pivot shaft; all /6 trans have this plate, but the /4 never did. So either have the plate drilled and tapped or try to find an original. [/quote] Sorry Dave but that is wrong. All tailshifts , 4 or 6 cyl had the threaded hole in the intermediate plate. You can not drill and tap the side shift plate as it does not have the boss. I will post pictures later as i have both types of plates |
| roundtwo |
Jul 23 2026, 05:00 PM
[quote name='bdstone914' date='Jul 22 2026, 06:12 AM' post='3265935']
@davep ' date='Jul 22 2026, 05:17 AM' post='3265914'] [quote name='roundtwo' post='3265850' date='Jul 21 2026, 01:14 PM'] Can you describe what this is? :"The set requires an intermediate plate with the threaded boss for the bell crank." [/quote] Todd, the transmission case has 3 parts, the main case, the tail cover, and the intermediate plate. This plate has to have the threaded hole for the pivot shaft; all /6 trans have this plate, but the /4 never did. So either have the plate drilled and tapped or try to find an original. [/quote] Sorry Dave but that is wrong. All tailshifts , 4 or 6 cyl had the threaded hole in the intermediate plate. You can not drill and tap the side shift plate as it does not have the boss. I will post pictures later as i have both types of plates [/quote] @bdstone914 Looks like I'm out of luck. Have a side shift 901. Thanks Bruce |
| bdstone914 |
Jul 23 2026, 07:43 PM
@roundtwo
@bdstone914 Looks like I'm out of luck. Have a side shift 901. Thanks Bruce [/quote] Not necessarily. This is a bracket that used to be available to use a side shift trans and mount the post. I bolts to the two lower tail cone studs. I think i can reproduce a bracket like that. |
bdstone914 FS Reproduction 914-6 style accelerator linkage sets Jul 17 2026, 10:25 PM
914Sixer Real world solutions for hard to find parts. Like... Jul 18 2026, 06:26 AM
bdstone914 @Luke M
[b]@[url=http://www.914world.com/bbs2/in... Jul 18 2026, 08:11 AM
bdstone914 @mate914
[b]@[url=http://www.914world.com/bbs2/i... Jul 18 2026, 08:13 AM
bdstone914 @GTS
[b]@[url=http://www.914world.com/bbs2/index... Jul 18 2026, 08:15 AM
scrz914 Nice Bruce. Stainless steel and adjustability are ... Jul 18 2026, 09:15 AM
bdstone914
Nice Bruce. Stainless steel and adjustability are... Jul 18 2026, 10:21 AM
mepstein I’m in for a set. Thanks Jul 18 2026, 11:03 AM
Jett I’m in for a set please Jul 18 2026, 06:25 PM
mate914 I'm in for a set also. Jul 19 2026, 07:11 AM
racer914 I will take a set Jul 19 2026, 07:13 AM
bdstone914
I will take a set
PM send. I need your full addr... Jul 19 2026, 07:44 AM
rick 918-S Thanks for the notification Bruce. I am in if I do... Jul 19 2026, 09:46 AM
NARP74 What is everyone currently using if they don't... Jul 20 2026, 08:39 PM
bdstone914 @[url=http://www.914world.com/bbs2/index.php?showu... Jul 20 2026, 11:36 PM
mb911 Bruce,
I am in for a set and would also like to p... Jul 21 2026, 04:43 AM
bdstone914 @[url=http://www.914world.com/bbs2/index.php?showu... Jul 22 2026, 07:20 AM
NARP74 What cable does this use? Jul 21 2026, 08:26 AM
914Wes
It is setup for the st... Jul 21 2026, 09:09 AM
bdstone914 @[url=http://www.914world.com/bbs2/index.php?showu... Jul 23 2026, 07:47 PM
Luke M
@[url=http://www.914world.com/bbs2/index.php?show... Jul 24 2026, 02:40 PM
roundtwo
[quote name='bdstone914' date='Jul 23... Jul 24 2026, 10:07 PM
Aerostatwv Hello, Bruce!
Please put me down for a set as... Jul 21 2026, 04:41 PM
billh1963 I'm in if you have a side shift solution.
Tha... Jul 24 2026, 12:35 PM
dug Any progress updates? Aug 25 2026, 07:11 PM
yellowporky Bruce,
I sent you a pm a couple weeks ago asking f... Sep 1 2026, 09:13 PM
bdstone914 @[url=http://www.914world.com/bbs2/index.php?showu... Sep 2 2026, 07:46 AM
dug Very cool Bruce! Thanks for doing this:) Sep 2 2026, 10:13 AM
racer914 Bruce -
Any traction on the sideshift version? I ... Sep 2 2026, 12:07 PM
bdstone914
Bruce -
Any traction on the sideshift version? I... Sep 2 2026, 09:01 PM
pencap914 Count me in for a set if there's a solution to... Sep 24 2026, 10:52 AM
yellowporky Bruce, any update?
Thanks
Chris Oct 30 2026, 07:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th October 2026 - 11:53 PM |
