> 914World Classifieds Rules
> FS Reproduction 914-6 style accelerator linkage sets, $225 early group buy or $250 later
bdstone914
post Jul 17 2026, 10:25 PM
bdstone914
I have the first prototype parts for the 914-6 style accelerator cable bracket, bell crank and linkage pull rod.
I redesigned the pull rod and bell crank. The cable support support bracket is 3D printed in stainless steel for increased strenght and rust prevension.
The bell crank and pull rod use metric ball sockets wirh a safety wire clip and dust cover to prevent dirt from entering the socket.
The pull rod uses two ball sockets unlike the original rod which uses a wire loop that wears.
All parts will be yellow zinc plated.
The bell crank is made with sloted holes to adjust the throttle modulation. The pull rod lenght is adjustable as it is a hollow tube connecting two ball sockets with all thread.
The set will include an original pivot post with plastic bushings.
The set requires an intermediate plate with the threaded boss for the bell crank. These were used on tail shift and 914-6 transmissions.
Group buy price now is $225. It will increase to $250 when i have full production in 2-3 weeks.
At this time i only have 10 accelerator brackets but can get more in about two weeks.
I prefer payment by Zelle or check image.
Shipping at cost by UPS ground.
I used a piece of all thread in the pictures in place of an actual accelerator cable.
roundtwo
post Jul 21 2026, 11:14 AM
@bdstone914
Hi Bruce,
I have a 1973 with side shift 3.0 liter six with PMOs.
Does the kit contain everything I need to convert from the basic cable pull right to the carbs?
Can you describe what this is? :"The set requires an intermediate plate with the threaded boss for the bell crank."
If so, I'd like to buy the set.
I can send you pics of my current set up if needed.
Thanks, Todd
davep
post Jul 22 2026, 06:17 AM
914 Historian
QUOTE(roundtwo @ Jul 21 2026, 01:14 PM) *
Todd, the transmission case has 3 parts, the main case, the tail cover, and the intermediate plate. This plate has to have the threaded hole for the pivot shaft; all /6 trans have this plate, but the /4 never did. So either have the plate drilled and tapped or try to find an original.
bdstone914
post Jul 22 2026, 07:12 AM
bdstone914
@davep
' date='Jul 22 2026, 05:17 AM' post='3265914']
[quote name='roundtwo' post='3265850' date='Jul 21 2026, 01:14 PM']
[/quote]
[/quote]
Sorry Dave but that is wrong. All tailshifts , 4 or 6 cyl had the threaded hole in the intermediate plate.
You can not drill and tap the side shift plate as it does not have the boss.
I will post pictures later as i have both types of plates
roundtwo
post Jul 23 2026, 05:00 PM
[quote name='bdstone914' date='Jul 22 2026, 06:12 AM' post='3265935']
@davep
[/quote]
[/quote]
[/quote]
@bdstone914
Looks like I'm out of luck. Have a side shift 901.
Thanks Bruce
bdstone914
post Jul 23 2026, 07:47 PM
bdstone914
@roundtwo
@bdstone914
Thanks Bruce
[/quote]
Not necessarily. This is a bracket that used to be available to use a side shift trans and mount the post.
I bolts to the two lower tail cone studs.
I think i can reproduce a bracket like that.
Luke M
post Jul 24 2026, 02:40 PM
[quote name='bdstone914' date='Jul 23 2026, 06:47 PM' post='3266110']
@roundtwo
@bdstone914
Thanks Bruce
[/quote]
[/quote]
If Bruce can make these side shift brackets that would be great. I've made a few in the past. I made one for my brothers 6 conversion a while back too. It doesn't look as nice as what's posted but it works.
roundtwo
post Jul 24 2026, 10:07 PM
[quote name='Luke M' date='Jul 24 2026, 01:40 PM' post='3266196']
@roundtwo
@bdstone914
Thanks Bruce
[/quote]
[/quote]
[/quote]
Well that will do the trick. I imagine it does need to be super stout as there's not a ton of force on it.
bdstone914   FS Reproduction 914-6 style accelerator linkage sets   Jul 17 2026, 10:25 PM
914Sixer   Real world solutions for hard to find parts. Like...   Jul 18 2026, 06:26 AM
bdstone914   @Luke M [b]@[url=http://www.914world.com/bbs2/in...   Jul 18 2026, 08:11 AM
bdstone914   @mate914 [b]@[url=http://www.914world.com/bbs2/i...   Jul 18 2026, 08:13 AM
bdstone914   @GTS [b]@[url=http://www.914world.com/bbs2/index...   Jul 18 2026, 08:15 AM
scrz914   Nice Bruce. Stainless steel and adjustability are ...   Jul 18 2026, 09:15 AM
bdstone914   Nice Bruce. Stainless steel and adjustability are...   Jul 18 2026, 10:21 AM
mepstein   I’m in for a set. Thanks   Jul 18 2026, 11:03 AM
Jett   I’m in for a set please   Jul 18 2026, 06:25 PM
mate914   I'm in for a set also.   Jul 19 2026, 07:11 AM
racer914   I will take a set   Jul 19 2026, 07:13 AM
bdstone914   I will take a set PM send. I need your full addr...   Jul 19 2026, 07:44 AM
rick 918-S   Thanks for the notification Bruce. I am in if I do...   Jul 19 2026, 09:46 AM
NARP74   What is everyone currently using if they don't...   Jul 20 2026, 08:39 PM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?showu...   Jul 20 2026, 11:36 PM
mb911   Bruce, I am in for a set and would also like to p...   Jul 21 2026, 04:43 AM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?showu...   Jul 22 2026, 07:20 AM
NARP74   What cable does this use?   Jul 21 2026, 08:26 AM
914Wes   What cable does this use? It is setup for the st...   Jul 21 2026, 09:09 AM
roundtwo   @bdstone914 Hi Bruce, I have a 1973 with side s...   Jul 21 2026, 11:14 AM
davep   Can you describe what this is? :"The set req...   Jul 22 2026, 06:17 AM
bdstone914   @davep ' date='Jul 22 2026, 05:17 AM...   Jul 22 2026, 07:12 AM
roundtwo   @[url=http://www.914world.com/bbs2/index.php?show...   Jul 23 2026, 05:00 PM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?showu...   Jul 23 2026, 07:43 PM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?showu...   Jul 23 2026, 07:47 PM
Luke M   @[url=http://www.914world.com/bbs2/index.php?show...   Jul 24 2026, 02:40 PM
roundtwo   [quote name='bdstone914' date='Jul 23...   Jul 24 2026, 10:07 PM
Aerostatwv   Hello, Bruce! Please put me down for a set as...   Jul 21 2026, 04:41 PM
billh1963   I'm in if you have a side shift solution. Tha...   Jul 24 2026, 12:35 PM
dug   Any progress updates?   Aug 25 2026, 07:11 PM
yellowporky   Bruce, I sent you a pm a couple weeks ago asking f...   Sep 1 2026, 09:13 PM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?showu...   Sep 2 2026, 07:46 AM
dug   Very cool Bruce! Thanks for doing this:)   Sep 2 2026, 10:13 AM
racer914   Bruce - Any traction on the sideshift version? I ...   Sep 2 2026, 12:07 PM
bdstone914   Bruce - Any traction on the sideshift version? I...   Sep 2 2026, 09:01 PM
pencap914   Count me in for a set if there's a solution to...   Sep 24 2026, 10:52 AM
yellowporky   Bruce, any update? Thanks Chris   Oct 30 2026, 07:41 PM
- Lo-Fi Version Time is now: 31st October 2026 - 12:57 AM
