| ConeDodger |
Oct 23 2026, 09:19 AM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,661 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Rocky Mountains
Ok, for those of you who have put a 915 in your 914, what are the linkage requirements? Does it just magically connect to the same 901 linkage? I didn’t think so…
What do I need? Currently running the JWest shifter for the 901. |
| Maltese Falcon |
Oct 25 2026, 08:42 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,467 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Jaide Car Co. or very early Rengade also had an adapter mechanism which attached to the tail shifter of the 915 transaxle. I discovered it in my shop racks the other day while re-arranging shop stuff.
Picture coming in a day or two. Looks like when installed, the mechanism would sit 10" past the license plate (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/marty914.jpg) |
| mepstein |
Oct 25 2026, 10:17 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,013 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Jade Car Co. or very early Rengade also had an adapter mechanism which attached to the tail shifter of the 915 transaxle. I discovered it in my shop racks the other day while re-arranging shop stuff. Picture coming in a day or two. Looks like when installed, the mechanism would sit 10" past the license plate (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/marty914.jpg) That was another challenge with the cable shift. I didn’t really want independent mufflers. The Martin Bott kit is really pricey but if you want the equivalent of a 914 side shift trans, it’s really the best way to go. I’m custom gearing both the 915 trans in my 67 and my 914. Peter Dawe told me it’s the best performance upgrade you can make on a car. We’ve done it on a couple customers cars and it’s true. It takes the whole driving experience to another level. It doesn’t sound like it should but having the right gear for every shift is amazing. |
| Steve |
Oct 25 2026, 10:47 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,132 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Jade Car Co. or very early Rengade also had an adapter mechanism which attached to the tail shifter of the 915 transaxle. I discovered it in my shop racks the other day while re-arranging shop stuff. Picture coming in a day or two. Looks like when installed, the mechanism would sit 10" past the license plate (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/marty914.jpg) That was another challenge with the cable shift. I didn’t really want independent mufflers. The Martin Bott kit is really pricey but if you want the equivalent of a 914 side shift trans, it’s really the best way to go. I’m custom gearing both the 915 trans in my 67 and my 914. Peter Dawe told me it’s the best performance upgrade you can make on a car. We’ve done it on a couple customers cars and it’s true. It takes the whole driving experience to another level. It doesn’t sound like it should but having the right gear for every shift is amazing. (IMG:style_emoticons/default/agree.gif) I had PMS go through my 916 trans, the previous two well known Porsche shops in so cal, could not figure it out. The car now shifts better than my 901 trans ever did. I just finished my second autocross with it. What a blast with the 3.6. But... I am curious if the Boxster S / Caymen S six speed kit would be a better option now for bigger motors. |
ConeDodger 915 transaxle into 914-6 questions Oct 23 2026, 09:19 AM
Steve
Ok, for those of you who have put a 915 in your 9... Oct 23 2026, 10:04 AM
Luke M
Ok, for those of you who have put a 915 in your ... Oct 23 2026, 11:49 AM
[quote name='Steve' post='3276112' date='Oct 23 2... Oct 23 2026, 12:54 PM
SirAndy The kit cost $5500-6k depending on which one ... Oct 23 2026, 01:37 PM
The kit cost $5500-6k depending on which one... Oct 23 2026, 02:01 PM
[quote name='SirAndy' post='3276136' date='Oct 23... Oct 23 2026, 03:30 PM
Steve
[quote name='SirAndy' post='3276136' date='Oct 2... Oct 23 2026, 03:34 PM
SirAndy Many moons ago i helped Brad adding a custom cable... Oct 23 2026, 10:12 AM
ConeDodger
Many moons ago i helped Brad adding a custom cabl... Oct 23 2026, 10:23 AM
Steve
Many moons ago i helped Brad adding a custom cabl... Oct 23 2026, 09:45 PM
Many moons ago i helped Brad adding a custom cab... Oct 24 2026, 05:40 AM
Steve
[quote name='Steve' post='3276185' date='Oct 23 2... Oct 24 2026, 06:41 PM
mepstein I’m building two Martin Bott 916 kits right now.... Oct 23 2026, 10:22 AM
Steve I am happy with my 915/916 conversion. It also ha... Oct 23 2026, 10:30 AM
mepstein I had the cable shifter and a PMS tubular transmis... Oct 25 2026, 07:30 AM
[quote name='mepstein' post='3276343' date='Oct 2... Oct 25 2026, 11:33 AM
Maltese Falcon The 20th Century Jaide kit for 915 trans, into the... Oct 25 2026, 02:05 PM
The 20th Century Jaide kit for 915 trans, into th... Oct 25 2026, 03:18 PM
Maltese Falcon
The 20th Century Jaide kit for 915 trans, into t... Oct 25 2026, 06:58 PM
[quote name='mepstein' post='3276359' date='Oct 2... Oct 25 2026, 07:21 PM
Maltese Falcon ...now I'm thinking that the original design f... Oct 25 2026, 02:32 PM
East coaster Is Wevo still a thing? I had a Wevo converted 915 ... Oct 25 2026, 07:22 PM
Is Wevo still a thing? I had a Wevo converted 915... Oct 25 2026, 08:09 PM
erwan914 15 years ago, I put together this setup using the ... Oct 26 2026, 12:38 AM
SirAndy 15 years ago, I put together this setup using the ... Oct 26 2026, 11:18 AM
Krieger
15 years ago, I put together this setup using the... Oct 26 2026, 12:33 PM
gereed75 Erwan. That looks really slick. Fully adjustable ... Oct 26 2026, 06:44 PM
erwan914
Erwan. That looks really slick. Fully adjustable... Oct 27 2026, 12:56 AM
sixnotfour :beer2:
one Obstacle....no bannana mufflers Oct 27 2026, 03:55 AM
sixnotfour Porsche gearbox Ferrari twin Turb0 308 Custom..
Pa... Oct 27 2026, 04:49 AM
brant Dang that car looks awesome Jeff! Oct 27 2026, 10:51 AM
live free & drive Cheap solution?
https://www.ebay.com/itm/23714248... Oct 28 2026, 09:47 AM
rgalla9146 I have Martin Bott 916 conversion kit in my GT pro... Oct 28 2026, 02:48 PM
Luke M
I have Martin Bott 916 conversion kit in my GT pr... Oct 29 2026, 04:48 AM
Steve
[quote name='rgalla9146' post='3276716' date='Oct... Oct 29 2026, 07:42 AM
rgalla9146
[quote name='rgalla9146' post='327671... Oct 29 2026, 04:06 PM
scallyk9
[quote name='rgalla9146' post='32767... Oct 29 2026, 04:32 PM
rgalla9146
[quote name='rgalla9146' date='Oct 29... Oct 29 2026, 05:25 PM
scallyk9 Something to check is the final drive ration on yo... Nov 1 2026, 06:39 PM
Steve
Something to check is the final drive ration on y... Nov 1 2026, 09:53 PM
Steve
I have Martin Bott 916 conversion kit in my GT pr... Oct 30 2026, 11:50 AM
rgalla9146
[quote name='rgalla9146' post='3276716' date='Oct... Oct 31 2026, 09:54 AM
[quote name='rgalla9146' post='3276716' date='Oc... Oct 31 2026, 10:35 AM
rgalla9146
[quote name='rgalla9146' post='3277044' date='Oct... Oct 31 2026, 04:04 PM
[quote name='rgalla9146' post='3277044' date='Oc... Oct 31 2026, 04:51 PM
rgalla9146
[quote name='rgalla9146' post='3277044' date='Oc... Oct 31 2026, 06:25 PM
dr914@autoatlanta.com Martin Bott, in Germany or cable shift, we just li... Oct 28 2026, 03:12 PM
914werke owner Couldnt find Gears..In his defense He was r... Oct 28 2026, 07:25 PM
mepstein Rory’s is a 72. First year use of 915 trans. Mec... Oct 29 2026, 09:58 AM
Luke M Here's what my sensor looks like. The sensor b... Oct 29 2026, 04:17 PM
mepstein Probably CMS - California Motorsports
https://cal... Oct 29 2026, 05:33 PM
sixnotfour Rory Said...
My cable driven speedo indicates 50 p... Oct 30 2026, 08:11 PM
Steve Rory,
Did you try reaching out to the guys in this... Oct 31 2026, 10:09 AM
mepstein I’m hoping the one I’m currently building will... Oct 31 2026, 07:26 PM
rgalla9146
I’m hoping the one I’m currently building wil... Nov 1 2026, 05:33 PM
sixnotfour Rory,, This Help ?
https://mrspeedometer.com/colle... Nov 2 2026, 12:16 AM
Rory,, This Help ?
https://mrspeedometer.com/coll... Nov 2 2026, 05:20 AM
sixnotfour
[quote name='sixnotfour' post='3277249' date='Nov... Nov 2 2026, 10:05 AM
[quote name='sixnotfour' post='3277249' date='No... Nov 2 2026, 12:43 PM
rgalla9146 Martin Bott replied:
Hi Rory,
you need to have... Nov 4 2026, 07:26 AM
mepstein So does that mean a mechanical speedo from a 72-77... Nov 4 2026, 09:01 AM
rgalla9146
So does that mean a mechanical speedo from a 72-7... Nov 4 2026, 11:55 AM
Steve
[quote name='mepstein' post='3277516' date='Nov 4... Nov 4 2026, 12:17 PM
rgalla9146
[quote name='mepstein' post='3277516' date='Nov ... Nov 4 2026, 03:47 PM
rgalla9146
So does that mean a mechanical speedo from a 72-7... Nov 9 2026, 06:19 AM
sixnotfour HELP.. @jbell
914-901 vs 915-911 speedometer r... Nov 4 2026, 03:50 PM
rgalla9146 John Bell did a 10K tach and a GT fuel gauge for m... Nov 4 2026, 08:24 PM
jbell959 The ratios of the 914 and 911 speedometers are dif... Nov 4 2026, 08:29 PM
sixnotfour @jbell ,, Thank You for your Knowledge...
Looks ... Nov 4 2026, 11:30 PM
mepstein I don’t believe the real 916 kit had that issue.... Nov 5 2026, 07:04 AM
rgalla9146 I have disassembled 914 transmissions and rear cov... Nov 5 2026, 10:03 PM
sixnotfour Well ,,I just got the Necessary parts from Johnny ... Nov 6 2026, 12:00 AM
rgalla9146 Shown with green background is the 914 speedo gear... Nov 6 2026, 11:01 AM
sixnotfour The exit ratio of the MB conversion versus the 914... Nov 8 2026, 10:38 AM
rgalla9146
The exit ratio of the MB conversion versus the 91... Nov 9 2026, 03:29 PM
sixnotfour Im Sure enjoying GRNMNEE's 8:31, aluminum case... Nov 8 2026, 10:57 AM
Steve
Im Sure enjoying GRNMNEE's 8:31, aluminum cas... Nov 8 2026, 09:01 PM
sixnotfour :stir:
I sent Ron a message... He maybe the simp... Nov 8 2026, 10:37 PM
Steve
:stir:
I sent Ron a message... He maybe the sim... Nov 9 2026, 08:17 AM
:stir:
I sent Ron a message... He maybe the si... Nov 9 2026, 09:23 AM
rgalla9146 So... Ron, Rory, Steve and Jeff all got Martins ki... Nov 9 2026, 11:40 AM
mepstein I have the kit and core 915 trans so if you need a... Nov 9 2026, 01:25 PM
sixnotfour I got the pics off the web,, I can get gear count ... Nov 13 2026, 12:27 PM
Steve
I got the pics off the web,, I can get gear count... Nov 13 2026, 10:35 PM
rgalla9146
I got the pics off the web,, I can get gear count... Nov 14 2026, 12:47 PM
ConeDodger Having purchased some parts from WEVO, I recognize... Nov 13 2026, 11:09 PM
rgalla9146 I've installed a Speedhut Speedbox (SDU-A-374)... Nov 20 2026, 02:56 PM
rgalla9146 pic 2 Nov 20 2026, 03:02 PM
rgalla9146 pic 3 Nov 20 2026, 03:03 PM
sixnotfour Nice Progression...No Speeding Tickets.. Nov 20 2026, 03:25 PM
sixnotfour Well... AL. or Mag. ?? I have both,,
tail shifted... Nov 21 2026, 05:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd November 2026 - 07:14 AM |
