| ConeDodger |
Oct 23 2026, 09:19 AM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,661 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Rocky Mountains
Ok, for those of you who have put a 915 in your 914, what are the linkage requirements? Does it just magically connect to the same 901 linkage? I didn’t think so…
What do I need? Currently running the JWest shifter for the 901. |
| rgalla9146 |
Oct 28 2026, 02:48 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,030 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
I have Martin Bott 916 conversion kit in my GT project on a magnesium case 1972 915 trans. I had a friend flip the differential and rebuild the ZF limited slip. I rebuilt the rest of the trans and located and mounted a bracket inside that is a necessary part of of the conversion It as now in my car and working. I have two issues. I'm using a 1972 911 shifter which is a 'one year only 'item, it looks the same as a 914 rear shifter but is quite different in detail to suit the 915 shift pattern. The linkage between the shifter and trans is similar to a 914 rear shift and is adjusted in the same way. Adjustment is difficult and is still not perfect. I supplied the 915 shifter parts Bott needed to modify for the kit. I also provided the stock 911 speedo drive parts. My cable driven speedo indicates 50 percent too high. At 50 mph (gps) it indicates ~ 100 mph I've tried different speedos. Same result. No solution yet, but haven't chased it too much either. Ideas ? |
| Luke M |
Oct 29 2026, 04:48 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,623 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
I have Martin Bott 916 conversion kit in my GT project on a magnesium case 1972 915 trans. I had a friend flip the differential and rebuild the ZF limited slip. I rebuilt the rest of the trans and located and mounted a bracket inside that is a necessary part of of the conversion It as now in my car and working. I have two issues. I'm using a 1972 911 shifter which is a 'one year only 'item, it looks the same as a 914 rear shifter but is quite different in detail to suit the 915 shift pattern. The linkage between the shifter and trans is similar to a 914 rear shift and is adjusted in the same way. Adjustment is difficult and is still not perfect. I supplied the 915 shifter parts Bott needed to modify for the kit. I also provided the stock 911 speedo drive parts. My cable driven speedo indicates 50 percent too high. At 50 mph (gps) it indicates ~ 100 mph I've tried different speedos. Same result. No solution yet, but haven't chased it too much either. Ideas ? Hi Rory, When PMS did my Bott 915/916 conversion they also installed a sensor for an electric speedo. I'd have to dig through some paperwork to find out what they ended up using. The bracket and sensor mount right on the trans/cv output shaft. Then you'd have to run wires to and from the speedo/sensor. I'll see if I have pics of the bracket and sensor. |
ConeDodger 915 transaxle into 914-6 questions Oct 23 2026, 09:19 AM
Steve
Ok, for those of you who have put a 915 in your 9... Oct 23 2026, 10:04 AM
Luke M
Ok, for those of you who have put a 915 in your ... Oct 23 2026, 11:49 AM
[quote name='Steve' post='3276112' date='Oct 23 2... Oct 23 2026, 12:54 PM
SirAndy The kit cost $5500-6k depending on which one ... Oct 23 2026, 01:37 PM
The kit cost $5500-6k depending on which one... Oct 23 2026, 02:01 PM
[quote name='SirAndy' post='3276136' date='Oct 23... Oct 23 2026, 03:30 PM
Steve
[quote name='SirAndy' post='3276136' date='Oct 2... Oct 23 2026, 03:34 PM
SirAndy Many moons ago i helped Brad adding a custom cable... Oct 23 2026, 10:12 AM
ConeDodger
Many moons ago i helped Brad adding a custom cabl... Oct 23 2026, 10:23 AM
Steve
Many moons ago i helped Brad adding a custom cabl... Oct 23 2026, 09:45 PM
Many moons ago i helped Brad adding a custom cab... Oct 24 2026, 05:40 AM
Steve
[quote name='Steve' post='3276185' date='Oct 23 2... Oct 24 2026, 06:41 PM
mepstein I’m building two Martin Bott 916 kits right now.... Oct 23 2026, 10:22 AM
Steve I am happy with my 915/916 conversion. It also ha... Oct 23 2026, 10:30 AM
mepstein I had the cable shifter and a PMS tubular transmis... Oct 25 2026, 07:30 AM
Maltese Falcon Jaide Car Co. or very early Rengade also had an ad... Oct 25 2026, 08:42 AM
Jade Car Co. or very early Rengade also had an ad... Oct 25 2026, 10:17 AM
Steve
Jade Car Co. or very early Rengade also had an a... Oct 25 2026, 10:47 AM
[quote name='mepstein' post='3276343' date='Oct 2... Oct 25 2026, 11:33 AM
Maltese Falcon The 20th Century Jaide kit for 915 trans, into the... Oct 25 2026, 02:05 PM
The 20th Century Jaide kit for 915 trans, into th... Oct 25 2026, 03:18 PM
Maltese Falcon
The 20th Century Jaide kit for 915 trans, into t... Oct 25 2026, 06:58 PM
[quote name='mepstein' post='3276359' date='Oct 2... Oct 25 2026, 07:21 PM
Maltese Falcon ...now I'm thinking that the original design f... Oct 25 2026, 02:32 PM
East coaster Is Wevo still a thing? I had a Wevo converted 915 ... Oct 25 2026, 07:22 PM
Is Wevo still a thing? I had a Wevo converted 915... Oct 25 2026, 08:09 PM
erwan914 15 years ago, I put together this setup using the ... Oct 26 2026, 12:38 AM
SirAndy 15 years ago, I put together this setup using the ... Oct 26 2026, 11:18 AM
Krieger
15 years ago, I put together this setup using the... Oct 26 2026, 12:33 PM
gereed75 Erwan. That looks really slick. Fully adjustable ... Oct 26 2026, 06:44 PM
erwan914
Erwan. That looks really slick. Fully adjustable... Oct 27 2026, 12:56 AM
sixnotfour :beer2:
one Obstacle....no bannana mufflers Oct 27 2026, 03:55 AM
sixnotfour Porsche gearbox Ferrari twin Turb0 308 Custom..
Pa... Oct 27 2026, 04:49 AM
brant Dang that car looks awesome Jeff! Oct 27 2026, 10:51 AM
live free & drive Cheap solution?
https://www.ebay.com/itm/23714248... Oct 28 2026, 09:47 AM
Steve
[quote name='rgalla9146' post='3276716' date='Oct... Oct 29 2026, 07:42 AM
rgalla9146
[quote name='rgalla9146' post='327671... Oct 29 2026, 04:06 PM
scallyk9
[quote name='rgalla9146' post='32767... Oct 29 2026, 04:32 PM
rgalla9146
[quote name='rgalla9146' date='Oct 29... Oct 29 2026, 05:25 PM
scallyk9 Something to check is the final drive ration on yo... Nov 1 2026, 06:39 PM
Steve
Something to check is the final drive ration on y... Nov 1 2026, 09:53 PM
Steve
I have Martin Bott 916 conversion kit in my GT pr... Oct 30 2026, 11:50 AM
rgalla9146
[quote name='rgalla9146' post='3276716' date='Oct... Oct 31 2026, 09:54 AM
[quote name='rgalla9146' post='3276716' date='Oc... Oct 31 2026, 10:35 AM
rgalla9146
[quote name='rgalla9146' post='3277044' date='Oct... Oct 31 2026, 04:04 PM
[quote name='rgalla9146' post='3277044' date='Oc... Oct 31 2026, 04:51 PM
rgalla9146
[quote name='rgalla9146' post='3277044' date='Oc... Oct 31 2026, 06:25 PM
dr914@autoatlanta.com Martin Bott, in Germany or cable shift, we just li... Oct 28 2026, 03:12 PM
914werke owner Couldnt find Gears..In his defense He was r... Oct 28 2026, 07:25 PM
mepstein Rory’s is a 72. First year use of 915 trans. Mec... Oct 29 2026, 09:58 AM
Luke M Here's what my sensor looks like. The sensor b... Oct 29 2026, 04:17 PM
mepstein Probably CMS - California Motorsports
https://cal... Oct 29 2026, 05:33 PM
sixnotfour Rory Said...
My cable driven speedo indicates 50 p... Oct 30 2026, 08:11 PM
Steve Rory,
Did you try reaching out to the guys in this... Oct 31 2026, 10:09 AM
mepstein I’m hoping the one I’m currently building will... Oct 31 2026, 07:26 PM
rgalla9146
I’m hoping the one I’m currently building wil... Nov 1 2026, 05:33 PM
sixnotfour Rory,, This Help ?
https://mrspeedometer.com/colle... Nov 2 2026, 12:16 AM
Rory,, This Help ?
https://mrspeedometer.com/coll... Nov 2 2026, 05:20 AM
sixnotfour
[quote name='sixnotfour' post='3277249' date='Nov... Nov 2 2026, 10:05 AM
[quote name='sixnotfour' post='3277249' date='No... Nov 2 2026, 12:43 PM
rgalla9146 Martin Bott replied:
Hi Rory,
you need to have... Nov 4 2026, 07:26 AM
mepstein So does that mean a mechanical speedo from a 72-77... Nov 4 2026, 09:01 AM
rgalla9146
So does that mean a mechanical speedo from a 72-7... Nov 4 2026, 11:55 AM
Steve
[quote name='mepstein' post='3277516' date='Nov 4... Nov 4 2026, 12:17 PM
rgalla9146
[quote name='mepstein' post='3277516' date='Nov ... Nov 4 2026, 03:47 PM
rgalla9146
So does that mean a mechanical speedo from a 72-7... Nov 9 2026, 06:19 AM
sixnotfour HELP.. @jbell
914-901 vs 915-911 speedometer r... Nov 4 2026, 03:50 PM
rgalla9146 John Bell did a 10K tach and a GT fuel gauge for m... Nov 4 2026, 08:24 PM
jbell959 The ratios of the 914 and 911 speedometers are dif... Nov 4 2026, 08:29 PM
sixnotfour @jbell ,, Thank You for your Knowledge...
Looks ... Nov 4 2026, 11:30 PM
mepstein I don’t believe the real 916 kit had that issue.... Nov 5 2026, 07:04 AM
rgalla9146 I have disassembled 914 transmissions and rear cov... Nov 5 2026, 10:03 PM
sixnotfour Well ,,I just got the Necessary parts from Johnny ... Nov 6 2026, 12:00 AM
rgalla9146 Shown with green background is the 914 speedo gear... Nov 6 2026, 11:01 AM
sixnotfour The exit ratio of the MB conversion versus the 914... Nov 8 2026, 10:38 AM
rgalla9146
The exit ratio of the MB conversion versus the 91... Nov 9 2026, 03:29 PM
sixnotfour Im Sure enjoying GRNMNEE's 8:31, aluminum case... Nov 8 2026, 10:57 AM
Steve
Im Sure enjoying GRNMNEE's 8:31, aluminum cas... Nov 8 2026, 09:01 PM
sixnotfour :stir:
I sent Ron a message... He maybe the simp... Nov 8 2026, 10:37 PM
Steve
:stir:
I sent Ron a message... He maybe the sim... Nov 9 2026, 08:17 AM
:stir:
I sent Ron a message... He maybe the si... Nov 9 2026, 09:23 AM
rgalla9146 So... Ron, Rory, Steve and Jeff all got Martins ki... Nov 9 2026, 11:40 AM
mepstein I have the kit and core 915 trans so if you need a... Nov 9 2026, 01:25 PM
sixnotfour I got the pics off the web,, I can get gear count ... Nov 13 2026, 12:27 PM
Steve
I got the pics off the web,, I can get gear count... Nov 13 2026, 10:35 PM
rgalla9146
I got the pics off the web,, I can get gear count... Nov 14 2026, 12:47 PM
ConeDodger Having purchased some parts from WEVO, I recognize... Nov 13 2026, 11:09 PM
rgalla9146 I've installed a Speedhut Speedbox (SDU-A-374)... Nov 20 2026, 02:56 PM
rgalla9146 pic 2 Nov 20 2026, 03:02 PM
rgalla9146 pic 3 Nov 20 2026, 03:03 PM
sixnotfour Nice Progression...No Speeding Tickets.. Nov 20 2026, 03:25 PM
sixnotfour Well... AL. or Mag. ?? I have both,,
tail shifted... Nov 21 2026, 05:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd November 2026 - 07:14 AM |
