> 915 transaxle into 914-6 questions
ConeDodger
post Oct 23 2026, 09:19 AM
Apex killer!
Ok, for those of you who have put a 915 in your 914, what are the linkage requirements? Does it just magically connect to the same 901 linkage? I didn’t think so…
What do I need? Currently running the JWest shifter for the 901.
rgalla9146
post Oct 28 2026, 02:48 PM
I have Martin Bott 916 conversion kit in my GT project on a
magnesium case 1972 915 trans.
I had a friend flip the differential and rebuild the ZF limited slip.
I rebuilt the rest of the trans and located and mounted a bracket inside that is a
necessary part of of the conversion
It as now in my car and working.
I have two issues.
I'm using a 1972 911 shifter which is a 'one year only 'item, it looks the
same as a 914 rear shifter but is quite different in detail to suit the 915 shift pattern.
The linkage between the shifter and trans is similar to a 914 rear shift
and is adjusted in the same way. Adjustment is difficult and is still not perfect.
I supplied the 915 shifter parts Bott needed to modify for the kit.
I also provided the stock 911 speedo drive parts.
My cable driven speedo indicates 50 percent too high. At 50 mph (gps) it indicates
~ 100 mph I've tried different speedos. Same result.
No solution yet, but haven't chased it too much either. Ideas ?
Steve
post Oct 30 2026, 11:50 AM
QUOTE(rgalla9146 @ Oct 28 2026, 01:48 PM) *
I have two issues.
(IMG:style_emoticons/default/hijacked.gif)
@rgalla9146
Rory,
Curious what motor are you running? Most of the time people switch to the 915 for 3.2 or bigger motors, even though the factory 916's also used the early 7:31 ring & pinion 915 trans with up to 2.9 liter motors (Brutus and the Recaro fire engine 914-6GT), but that's all that was available at the time. The 914/901 trans is also 7:31, so what is the advantage of a 7:31 915? More reliable 1st gear? Better stock gearing? Period correct? Just curious. I know that some 911 owners switch to the earlier 7:31 915 trans because it was better for the track. Lower gears and close ratio shifting.
For me, I went with a 1986 915 8:31 ring & pinion trans for gearing that matched my 3.2. The 914 trans with the 3.2 drove me up the wall, since all the gears were too short for the street and I felt like I was shifting all the time. The later 915 trans also has an electronic speedometer and omega spring. The stock 8:31 Ring & Pinion 915 is awesome with the 3.6. The gears feel a little short compared to the 3.2, but it makes the car very quick. I still plan on changing 5th gear to the tallest 5th which is a TL 29:21 gear. This gear is the same as the stock G50 five speed 5th in a 964. It's also easy to change, since its in the nose cone. You don't have to remove the trans.
rgalla9146
post Oct 31 2026, 09:54 AM
QUOTE(Steve @ Oct 30 2026, 01:50 PM) *
I have two issues.
@rgalla9146
Rory,
Hey Steve
I went with the 915/916 because I intended to install a bigger 911 engine.
I've been delayed (big time) with what is now a 3.2 short stroke.
To keep the car mobil in the meantime a stock '68 911 2.0 is installed in front of
the 916 !
The 3.2 is almost ready.
My '72 915 most likely has the stock 7:31 ...I never thought to count the teeth
when it was apart .
Based on my experience driving the current combo I know a longer 5th gear is in
my future . 3800 rpm at 70 mph. Maybe other ratios as well.
When I first drove the car with the 916 the speed was obviously way off. I wrote to
Martin Bott but received no reply.
Did Bott say to someone here that a 'speedo adjustment' will be necessary ?
Do you know of anyone with a 916 and an operating mechanical speedo ?
I was told by an instrument specialist thay my speedo error is too great to be
corrected in the instrument.
TIA Rory
Any info from anyone is appreciated. A mechanical solution would be my first choice.
post Oct 31 2026, 10:35 AM
914-6 GT in waiting
QUOTE(rgalla9146 @ Oct 31 2026, 11:54 AM) *
I have two issues.
@rgalla9146
Rory,
Hey Steve
the 916 !
when it was apart .
TIA Rory
Rory - when you originally purchased the kit, did you send the speedo gear and other exchange pieces to the place in NJ. That was a requirement for my mechanical kit before Martin shipped from Germany.
ConeDodger   915 transaxle into 914-6 questions   Oct 23 2026, 09:19 AM
Steve   Ok, for those of you who have put a 915 in your 9...   Oct 23 2026, 10:04 AM
Luke M   Ok, for those of you who have put a 915 in your ...   Oct 23 2026, 11:49 AM
mepstein   [quote name='Steve' post='3276112' date='Oct 23 2...   Oct 23 2026, 12:54 PM
SirAndy   The kit cost $5500-6k depending on which one ...   Oct 23 2026, 01:37 PM
mepstein   The kit cost $5500-6k depending on which one...   Oct 23 2026, 02:01 PM
SirAndy   [quote name='SirAndy' post='3276136' date='Oct 23...   Oct 23 2026, 03:30 PM
Steve   [quote name='SirAndy' post='3276136' date='Oct 2...   Oct 23 2026, 03:34 PM
SirAndy   Many moons ago i helped Brad adding a custom cable...   Oct 23 2026, 10:12 AM
ConeDodger   Many moons ago i helped Brad adding a custom cabl...   Oct 23 2026, 10:23 AM
Steve   Many moons ago i helped Brad adding a custom cabl...   Oct 23 2026, 09:45 PM
mepstein   Many moons ago i helped Brad adding a custom cab...   Oct 24 2026, 05:40 AM
Steve   [quote name='Steve' post='3276185' date='Oct 23 2...   Oct 24 2026, 06:41 PM
mepstein   I’m building two Martin Bott 916 kits right now....   Oct 23 2026, 10:22 AM
Steve   I am happy with my 915/916 conversion. It also ha...   Oct 23 2026, 10:30 AM
mepstein   I had the cable shifter and a PMS tubular transmis...   Oct 25 2026, 07:30 AM
Maltese Falcon   Jaide Car Co. or very early Rengade also had an ad...   Oct 25 2026, 08:42 AM
mepstein   Jade Car Co. or very early Rengade also had an ad...   Oct 25 2026, 10:17 AM
Steve   Jade Car Co. or very early Rengade also had an a...   Oct 25 2026, 10:47 AM
mepstein   [quote name='mepstein' post='3276343' date='Oct 2...   Oct 25 2026, 11:33 AM
Maltese Falcon   The 20th Century Jaide kit for 915 trans, into the...   Oct 25 2026, 02:05 PM
mepstein   The 20th Century Jaide kit for 915 trans, into th...   Oct 25 2026, 03:18 PM
Maltese Falcon   The 20th Century Jaide kit for 915 trans, into t...   Oct 25 2026, 06:58 PM
mepstein   [quote name='mepstein' post='3276359' date='Oct 2...   Oct 25 2026, 07:21 PM
Maltese Falcon   ...now I'm thinking that the original design f...   Oct 25 2026, 02:32 PM
East coaster   Is Wevo still a thing? I had a Wevo converted 915 ...   Oct 25 2026, 07:22 PM
mepstein   Is Wevo still a thing? I had a Wevo converted 915...   Oct 25 2026, 08:09 PM
erwan914   15 years ago, I put together this setup using the ...   Oct 26 2026, 12:38 AM
SirAndy   15 years ago, I put together this setup using the ...   Oct 26 2026, 11:18 AM
Krieger   15 years ago, I put together this setup using the...   Oct 26 2026, 12:33 PM
gereed75   Erwan. That looks really slick. Fully adjustable ...   Oct 26 2026, 06:44 PM
erwan914   Erwan. That looks really slick. Fully adjustable...   Oct 27 2026, 12:56 AM
sixnotfour   :beer2: one Obstacle....no bannana mufflers   Oct 27 2026, 03:55 AM
sixnotfour   Porsche gearbox Ferrari twin Turb0 308 Custom.. Pa...   Oct 27 2026, 04:49 AM
brant   Dang that car looks awesome Jeff!   Oct 27 2026, 10:51 AM
live free & drive   Cheap solution? https://www.ebay.com/itm/23714248...   Oct 28 2026, 09:47 AM
rgalla9146   I have Martin Bott 916 conversion kit in my GT pro...   Oct 28 2026, 02:48 PM
Luke M   I have Martin Bott 916 conversion kit in my GT pr...   Oct 29 2026, 04:48 AM
Steve   [quote name='rgalla9146' post='3276716' date='Oct...   Oct 29 2026, 07:42 AM
rgalla9146   [quote name='rgalla9146' post='327671...   Oct 29 2026, 04:06 PM
scallyk9   [quote name='rgalla9146' post='32767...   Oct 29 2026, 04:32 PM
rgalla9146   [quote name='rgalla9146' date='Oct 29...   Oct 29 2026, 05:25 PM
scallyk9   Something to check is the final drive ration on yo...   Nov 1 2026, 06:39 PM
Steve   Something to check is the final drive ration on y...   Nov 1 2026, 09:53 PM
Steve   I have Martin Bott 916 conversion kit in my GT pr...   Oct 30 2026, 11:50 AM
rgalla9146   [quote name='rgalla9146' post='3276716' date='Oct...   Oct 31 2026, 09:54 AM
mepstein   [quote name='rgalla9146' post='3276716' date='Oc...   Oct 31 2026, 10:35 AM
rgalla9146   [quote name='rgalla9146' post='3277044' date='Oct...   Oct 31 2026, 04:04 PM
mepstein   [quote name='rgalla9146' post='3277044' date='Oc...   Oct 31 2026, 04:51 PM
rgalla9146   [quote name='rgalla9146' post='3277044' date='Oc...   Oct 31 2026, 06:25 PM
dr914@autoatlanta.com   Martin Bott, in Germany or cable shift, we just li...   Oct 28 2026, 03:12 PM
914werke   owner Couldnt find Gears..In his defense He was r...   Oct 28 2026, 07:25 PM
mepstein   Rory’s is a 72. First year use of 915 trans. Mec...   Oct 29 2026, 09:58 AM
Luke M   Here's what my sensor looks like. The sensor b...   Oct 29 2026, 04:17 PM
mepstein   Probably CMS - California Motorsports https://cal...   Oct 29 2026, 05:33 PM
sixnotfour   Rory Said... My cable driven speedo indicates 50 p...   Oct 30 2026, 08:11 PM
Steve   Rory, Did you try reaching out to the guys in this...   Oct 31 2026, 10:09 AM
mepstein   I’m hoping the one I’m currently building will...   Oct 31 2026, 07:26 PM
rgalla9146   I’m hoping the one I’m currently building wil...   Nov 1 2026, 05:33 PM
sixnotfour   Rory,, This Help ? https://mrspeedometer.com/colle...   Nov 2 2026, 12:16 AM
mepstein   Rory,, This Help ? https://mrspeedometer.com/coll...   Nov 2 2026, 05:20 AM
sixnotfour   [quote name='sixnotfour' post='3277249' date='Nov...   Nov 2 2026, 10:05 AM
mepstein   [quote name='sixnotfour' post='3277249' date='No...   Nov 2 2026, 12:43 PM
rgalla9146   Martin Bott replied: Hi Rory, you need to have...   Nov 4 2026, 07:26 AM
mepstein   So does that mean a mechanical speedo from a 72-77...   Nov 4 2026, 09:01 AM
rgalla9146   So does that mean a mechanical speedo from a 72-7...   Nov 4 2026, 11:55 AM
Steve   [quote name='mepstein' post='3277516' date='Nov 4...   Nov 4 2026, 12:17 PM
rgalla9146   [quote name='mepstein' post='3277516' date='Nov ...   Nov 4 2026, 03:47 PM
rgalla9146   So does that mean a mechanical speedo from a 72-7...   Nov 9 2026, 06:19 AM
sixnotfour   HELP.. @jbell 914-901 vs 915-911 speedometer r...   Nov 4 2026, 03:50 PM
rgalla9146   John Bell did a 10K tach and a GT fuel gauge for m...   Nov 4 2026, 08:24 PM
jbell959   The ratios of the 914 and 911 speedometers are dif...   Nov 4 2026, 08:29 PM
sixnotfour   @jbell ,, Thank You for your Knowledge... Looks ...   Nov 4 2026, 11:30 PM
mepstein   I don’t believe the real 916 kit had that issue....   Nov 5 2026, 07:04 AM
rgalla9146   I have disassembled 914 transmissions and rear cov...   Nov 5 2026, 10:03 PM
sixnotfour   Well ,,I just got the Necessary parts from Johnny ...   Nov 6 2026, 12:00 AM
rgalla9146   Shown with green background is the 914 speedo gear...   Nov 6 2026, 11:01 AM
sixnotfour   The exit ratio of the MB conversion versus the 914...   Nov 8 2026, 10:38 AM
rgalla9146   The exit ratio of the MB conversion versus the 91...   Nov 9 2026, 03:29 PM
sixnotfour   Im Sure enjoying GRNMNEE's 8:31, aluminum case...   Nov 8 2026, 10:57 AM
Steve   Im Sure enjoying GRNMNEE's 8:31, aluminum cas...   Nov 8 2026, 09:01 PM
sixnotfour   :stir: I sent Ron a message... He maybe the simp...   Nov 8 2026, 10:37 PM
Steve   :stir: I sent Ron a message... He maybe the sim...   Nov 9 2026, 08:17 AM
mepstein   :stir: I sent Ron a message... He maybe the si...   Nov 9 2026, 09:23 AM
rgalla9146   So... Ron, Rory, Steve and Jeff all got Martins ki...   Nov 9 2026, 11:40 AM
mepstein   I have the kit and core 915 trans so if you need a...   Nov 9 2026, 01:25 PM
sixnotfour   I got the pics off the web,, I can get gear count ...   Nov 13 2026, 12:27 PM
Steve   I got the pics off the web,, I can get gear count...   Nov 13 2026, 10:35 PM
rgalla9146   I got the pics off the web,, I can get gear count...   Nov 14 2026, 12:47 PM
ConeDodger   Having purchased some parts from WEVO, I recognize...   Nov 13 2026, 11:09 PM
rgalla9146   I've installed a Speedhut Speedbox (SDU-A-374)...   Nov 20 2026, 02:56 PM
rgalla9146   pic 2   Nov 20 2026, 03:02 PM
rgalla9146   pic 3   Nov 20 2026, 03:03 PM
sixnotfour   Nice Progression...No Speeding Tickets..   Nov 20 2026, 03:25 PM
sixnotfour   Well... AL. or Mag. ?? I have both,, tail shifted...   Nov 21 2026, 05:01 PM
11 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
1 Members: sixnotfour
- Lo-Fi Version Time is now: 23rd November 2026 - 07:14 AM
