| malcolm2 |
Nov 2 2026, 05:31 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,756 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
Prior to changing anything, I used Krusty's method and got my thinnest gauge. I found a 0.002....
I had rotated the engine around and checked my 1. Swivel Foot on each valve. They spin. 2. I also checked for any rocker movement... or really I kept rotating until i got a CLICK when i wiggled the rocker and spun the Swivel. So at that point i was able to get the 0.002 gauge in. Remember, I am SHOOTING FOR ZERO LASH HERE Should I try make that small adjustment so the 0.002 gauge won't go in? KRUSTY'S Valve adjust method |
| Ishley |
Nov 2 2026, 08:58 PM
Member ![]() ![]() Group: Members Posts: 372 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest
I set mine up to what is called loose zero. I Tighten until I can feel it just come down on the pushrod but I can still spin it with my fingers. After I lock the nut down, I check if it still spins and I try to move the rocker to see if I can hear it click/clack. Sometimes it takes several attempts If I don’t hear anything and I can still spin the rod with my fingers I know I’m there.
Works for me. |
malcolm2 Valve Adjustment with Chromoly Push Rods Nov 2 2026, 05:31 PM
GregAmy My technique is the Krusty method, then slowly tig... Nov 2 2026, 06:25 PM
malcolm2 So you have never followed up with a gauge? You t... Nov 2 2026, 08:15 PM
GregAmy
I mea... Nov 2 2026, 08:33 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd November 2026 - 12:20 AM |
