| malcolm2 |
Nov 2 2026, 05:31 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,765 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
Prior to changing anything, I used Krusty's method and got my thinnest gauge. I found a 0.002....
I had rotated the engine around and checked my 1. Swivel Foot on each valve. They spin. 2. I also checked for any rocker movement... or really I kept rotating until i got a CLICK when i wiggled the rocker and spun the Swivel. So at that point i was able to get the 0.002 gauge in. Remember, I am SHOOTING FOR ZERO LASH HERE Should I try make that small adjustment so the 0.002 gauge won't go in? KRUSTY'S Valve adjust method |
| mgphoto |
Nov 4 2026, 02:18 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,512 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Zero for me using the chrome moly push rods means the rocker arm doesn’t move when pushed and I can still rotate the elephant foot.
malcolm2 Valve Adjustment with Chromoly Push Rods Nov 2 2026, 05:31 PM
GregAmy My technique is the Krusty method, then slowly tig... Nov 2 2026, 06:25 PM
malcolm2 So you have never followed up with a gauge? You t... Nov 2 2026, 08:15 PM
GregAmy
I mea... Nov 2 2026, 08:33 PM
Ishley I set mine up to what is called loose zero. I Tig... Nov 2 2026, 08:58 PM
malcolm2
I set mine up to what is called loose zero. I Ti... Nov 3 2026, 07:55 AM
Nogoodwithusernames I've never had anything except aluminum pushro... Nov 3 2026, 11:21 AM
malcolm2 Found a 0.0015 feeler. So i used that just to make... Nov 5 2026, 12:01 PM
malcolm2 Here we are.... 75 exhaust removed. Car raised HI... Nov 5 2026, 06:38 PM
GregAmy
Here we are.... 75 exhaust removed. Car raised H... Nov 6 2026, 07:56 AM
VaccaRabite Using feeler gauges to get zero clearance is way o... Nov 6 2026, 08:13 AM
iankarr It's helpful if you use a sharpie to mark the ... Nov 6 2026, 10:21 PM
malcolm2 Car has been jacked up for a few weeks now. I am n... Nov 9 2026, 03:33 PM
VaccaRabite
Car has been jacked up for a few weeks now. I am ... Nov 12 2026, 07:36 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2026 - 06:06 AM |
