| malcolm2 |
Nov 2 2026, 05:31 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,765 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
Prior to changing anything, I used Krusty's method and got my thinnest gauge. I found a 0.002....
I had rotated the engine around and checked my 1. Swivel Foot on each valve. They spin. 2. I also checked for any rocker movement... or really I kept rotating until i got a CLICK when i wiggled the rocker and spun the Swivel. So at that point i was able to get the 0.002 gauge in. Remember, I am SHOOTING FOR ZERO LASH HERE Should I try make that small adjustment so the 0.002 gauge won't go in? KRUSTY'S Valve adjust method |
| VaccaRabite |
Nov 6 2026, 08:13 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,946 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Using feeler gauges to get zero clearance is way overkill.
Turn the adjuster till it makes contact. Tighten it down. Wiggle it. Any click? No? Good. Can you still spin the foot? Yes? Good. Done. Are you hurting anything using a feeler? No. But you also aren't gaining anything. Zach |
malcolm2 Valve Adjustment with Chromoly Push Rods Nov 2 2026, 05:31 PM
GregAmy My technique is the Krusty method, then slowly tig... Nov 2 2026, 06:25 PM
malcolm2 So you have never followed up with a gauge? You t... Nov 2 2026, 08:15 PM
GregAmy
I mea... Nov 2 2026, 08:33 PM
Ishley I set mine up to what is called loose zero. I Tig... Nov 2 2026, 08:58 PM
malcolm2
I set mine up to what is called loose zero. I Ti... Nov 3 2026, 07:55 AM
Nogoodwithusernames I've never had anything except aluminum pushro... Nov 3 2026, 11:21 AM
mgphoto Zero for me using the chrome moly push rods means ... Nov 4 2026, 02:18 PM
malcolm2 Found a 0.0015 feeler. So i used that just to make... Nov 5 2026, 12:01 PM
malcolm2 Here we are.... 75 exhaust removed. Car raised HI... Nov 5 2026, 06:38 PM
GregAmy
Here we are.... 75 exhaust removed. Car raised H... Nov 6 2026, 07:56 AM
iankarr It's helpful if you use a sharpie to mark the ... Nov 6 2026, 10:21 PM
malcolm2 Car has been jacked up for a few weeks now. I am n... Nov 9 2026, 03:33 PM
VaccaRabite
Car has been jacked up for a few weeks now. I am ... Nov 12 2026, 07:36 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd November 2026 - 05:09 AM |
