| DC_neun_vierzehn |
Nov 2 2026, 08:28 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 696 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
Last night, I think my throttle cable snapped. I believe it snapped somewhere in the tunnel (bc it's still attached at both ends). Bummer bc I just put it on about 6 months ago. I thought I avoided wrapping it around the clutch cable, but I must not have.
Thus, I thought I would replace both cables "while I'm in there" this time (in case the wrapping/rubbing did any damage to the clutch cable). I thought I read in a post recently that if installing both cables, install the throttle cable first, then the clutch calbe, to help avoid the wrapping issue. Is that the correct order? I have a bore scope that I will use and will obviously be more careful this time. Any other helpful tips are welcomed. |
| DC_neun_vierzehn |
Nov 5 2026, 09:54 AM
Do the ball sockets attachments at the end of the throttle cable wear out and lead to occasional pop outs?
| BillC |
Nov 5 2026, 10:53 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 763 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region
Do the ball sockets attachments at the end of the throttle cable wear out and lead to occasional pop outs? Yes, if you have the kind of socket that has a little circumferential spring inside the opening of the socket cup -- that little circular spring can loose tension and the socket pops off easily. I prefer the socket version that uses an external retainer spring that slides into two holes in the socket and then clips around the socket shaft. This version generally won't pop off unless there is significant damage to the cup or retainer. And, if you don't have a retainer spring, either kind, the socket won't stay on at all. So here’s my question: would the wrapping cause the ball socket to pop off (6 months after installing the throttle cable)? Generally, if your throttle cable is wrapped around the clutch cable, you'll know because your gas pedal will want to move whenever you press or release the clutch. I think it's more likely that your throttle cable wrapped itself around the clutch cable after the worn socket popped loose. |
| DC_neun_vierzehn |
Nov 5 2026, 05:11 PM
Do the ball sockets attachments at the end of the throttle cable wear out and lead to occasional pop outs? Yes, if you have the kind of socket that has a little circumferential spring inside the opening of the socket cup -- that little circular spring can loose tension and the socket pops off easily. I prefer the socket version that uses an external retainer spring that slides into two holes in the socket and then clips around the socket shaft. This version generally won't pop off unless there is significant damage to the cup or retainer. And, if you don't have a retainer spring, either kind, the socket won't stay on at all. So here’s my question: would the wrapping cause the ball socket to pop off (6 months after installing the throttle cable)? Generally, if your throttle cable is wrapped around the clutch cable, you'll know because your gas pedal will want to move whenever you press or release the clutch. I think it's more likely that your throttle cable wrapped itself around the clutch cable after the worn socket popped loose. @BillC Rut-ro. I didn't see any sort of springs on this ball socket. Can you share pics of either version so I know what's missing? These pics are not my car, but this is the ball socket I'm talking about. Where are the springs in these pics? |
| BillC |
Nov 6 2026, 10:02 AM
Rut-ro. I didn't see any sort of springs on this ball socket. Can you share pics of either version so I know what's missing? Those are pics of sockets that have the retaining spring in the hole. If you look in the hole in the socket (where the ball goes), there will be a groove near the opening. In that groove should be a small circular spring clip. That clip retains the socket on the ball. If the spring clip is missing, or if it lost tension, the socket can pop off the ball easily. And, it is common for those spring clips to wear and/or lose tension over time, and usually you only get a certain number of times the socket can be popped off the ball before you need to replace the socket. Here's a (small) pic of the other kind of socket I was talking about: ![]() You can see the retaining spring that fits in a through-hole in the socket and then clips around the shank of the socket. This type seems more secure to me, and more re-usable as well. Another pic I found: ![]() |
DC_neun_vierzehn Clutch & throttle cable questions Nov 2 2026, 08:28 AM
BillC I don't think there's really any order dif... Nov 2 2026, 08:57 AM
DC_neun_vierzehn Also, check your engine ground -- a snapped clutc... Nov 2 2026, 09:50 AM
Shivers
Also, check your engine ground -- a snapped clut... Nov 2 2026, 10:02 AM
DC_neun_vierzehn
[quote name='DC_neun_vierzehn' post='3277287' dat... Nov 2 2026, 10:30 AM
DC_neun_vierzehn Well I dug into the job last night.
Good news: I... Nov 4 2026, 01:05 PM
DC_neun_vierzehn Duplicate post Nov 5 2026, 09:54 AM
914werke Make sure the jamb nut is tight to the socket, if ... Nov 5 2026, 07:14 PM
DC_neun_vierzehn So if I'm going to buy a ball socket piece rep... Nov 8 2026, 04:39 PM
BillC
So if I'm going to buy a ball socket piece re... Nov 8 2026, 07:28 PM
DC_neun_vierzehn
[quote name='DC_neun_vierzehn' post='3277966' dat... Nov 9 2026, 08:05 AM
StarBear Hmmmm. I might check mine as part of my season end... Nov 8 2026, 04:50 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd November 2026 - 05:18 PM |
