| DC_neun_vierzehn |
Nov 2 2026, 08:28 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 696 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
Last night, I think my throttle cable snapped. I believe it snapped somewhere in the tunnel (bc it's still attached at both ends). Bummer bc I just put it on about 6 months ago. I thought I avoided wrapping it around the clutch cable, but I must not have.
Thus, I thought I would replace both cables "while I'm in there" this time (in case the wrapping/rubbing did any damage to the clutch cable). I thought I read in a post recently that if installing both cables, install the throttle cable first, then the clutch calbe, to help avoid the wrapping issue. Is that the correct order? I have a bore scope that I will use and will obviously be more careful this time. Any other helpful tips are welcomed. |
| DC_neun_vierzehn |
Nov 8 2026, 04:39 PM
So if I'm going to buy a ball socket piece replacement ... should I buy the Genuine Porsche part or an upgraded aftermarket part?
Auto Atlanta sells the Genuine Porsche part for $26 (buying direct from a Porsche dealer is a few bucks less): https://www.autoatlanta.com/products/ball-c...=46741533786249 |
| BillC |
Nov 8 2026, 07:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 763 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region
So if I'm going to buy a ball socket piece replacement ... should I buy the Genuine Porsche part or an upgraded aftermarket part? Auto Atlanta sells the Genuine Porsche part for $26 (buying direct from a Porsche dealer is a few bucks less): https://www.autoatlanta.com/products/ball-c...=46741533786249 If it were me, I'd buy the type I pictured above, with the external retaining spring. The stock type will also work, I just prefer the external retainer type. |
| DC_neun_vierzehn |
Nov 9 2026, 08:05 AM
So if I'm going to buy a ball socket piece replacement ... should I buy the Genuine Porsche part or an upgraded aftermarket part? Auto Atlanta sells the Genuine Porsche part for $26 (buying direct from a Porsche dealer is a few bucks less): https://www.autoatlanta.com/products/ball-c...=46741533786249 If it were me, I'd buy the type I pictured above, with the external retaining spring. The stock type will also work, I just prefer the external retainer type. Do you have a link that you can share? |
DC_neun_vierzehn Clutch & throttle cable questions Nov 2 2026, 08:28 AM
BillC I don't think there's really any order dif... Nov 2 2026, 08:57 AM
DC_neun_vierzehn Also, check your engine ground -- a snapped clutc... Nov 2 2026, 09:50 AM
Shivers
Also, check your engine ground -- a snapped clut... Nov 2 2026, 10:02 AM
DC_neun_vierzehn
[quote name='DC_neun_vierzehn' post='3277287' dat... Nov 2 2026, 10:30 AM
DC_neun_vierzehn Well I dug into the job last night.
Good news: I... Nov 4 2026, 01:05 PM
DC_neun_vierzehn Duplicate post Nov 5 2026, 09:54 AM
DC_neun_vierzehn Do the ball sockets attachments at the end of the ... Nov 5 2026, 09:54 AM
BillC
Do the ball sockets attachments at the end of the... Nov 5 2026, 10:53 AM
DC_neun_vierzehn
Do the ball sockets attachments at the end of th... Nov 5 2026, 05:11 PM
BillC
Rut-ro. I didn't see any sort of springs on t... Nov 6 2026, 10:02 AM
914werke Make sure the jamb nut is tight to the socket, if ... Nov 5 2026, 07:14 PM
StarBear Hmmmm. I might check mine as part of my season end... Nov 8 2026, 04:50 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd November 2026 - 05:18 PM |
