| malcolm2 |
Nov 2 2026, 05:31 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,765 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
Prior to changing anything, I used Krusty's method and got my thinnest gauge. I found a 0.002....
I had rotated the engine around and checked my 1. Swivel Foot on each valve. They spin. 2. I also checked for any rocker movement... or really I kept rotating until i got a CLICK when i wiggled the rocker and spun the Swivel. So at that point i was able to get the 0.002 gauge in. Remember, I am SHOOTING FOR ZERO LASH HERE Should I try make that small adjustment so the 0.002 gauge won't go in? KRUSTY'S Valve adjust method |
| malcolm2 |
Nov 9 2026, 03:33 PM
Car has been jacked up for a few weeks now. I am not in a rush.
Feeler gets me all 4 close to the same. I can see the adjuster move ever so slightly as i tighten the lock nut. And i spin the swivel foot. I can’t get my fingers on the PR, so the foot is the ticket. Just to feel good, i did the whole process again yesterday. Had 2 valves that clicked and the 0.0015 went in too easy, so i got that squared away. No clicking on any rocker. I have been studying up on the valve cover gaskets. I found a few good suggestions. 1 guy used high temp grease to stick the gasket on the cover and help swell the cork, so a thin coat on the head side too. Another guy used gasgacinch on the cover side and grease on the head side. I went with that. Contact cement is setting now. |
| VaccaRabite |
Nov 12 2026, 07:36 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,946 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Car has been jacked up for a few weeks now. I am not in a rush. Feeler gets me all 4 close to the same. I can see the adjuster move ever so slightly as i tighten the lock nut. And i spin the swivel foot. I can’t get my fingers on the PR, so the foot is the ticket. Just to feel good, i did the whole process again yesterday. Had 2 valves that clicked and the 0.0015 went in too easy, so i got that squared away. No clicking on any rocker. I have been studying up on the valve cover gaskets. I found a few good suggestions. 1 guy used high temp grease to stick the gasket on the cover and help swell the cork, so a thin coat on the head side too. Another guy used gasgacinch on the cover side and grease on the head side. I went with that. Contact cement is setting now. Thin smear of RTV on the valve cover side of the gasket ONLY. There should not be sealant on the head side. This also makes the valve cover gasket reusable for years. When you do finally take them off the valve covers, there will be a considerable amount of cleaning that has to get done as you have to remove ALL the old RTV. It’s worth it though. My last set of valve covers gaskets lasted 5 years, with biannual valve checks and no leaks. My current set of valve cover gaskets have been on my car for three years now and going strong with no leaks. Zach |
malcolm2 Valve Adjustment with Chromoly Push Rods Nov 2 2026, 05:31 PM
GregAmy My technique is the Krusty method, then slowly tig... Nov 2 2026, 06:25 PM
malcolm2 So you have never followed up with a gauge? You t... Nov 2 2026, 08:15 PM
GregAmy
I mea... Nov 2 2026, 08:33 PM
Ishley I set mine up to what is called loose zero. I Tig... Nov 2 2026, 08:58 PM
malcolm2
I set mine up to what is called loose zero. I Ti... Nov 3 2026, 07:55 AM
Nogoodwithusernames I've never had anything except aluminum pushro... Nov 3 2026, 11:21 AM
mgphoto Zero for me using the chrome moly push rods means ... Nov 4 2026, 02:18 PM
malcolm2 Found a 0.0015 feeler. So i used that just to make... Nov 5 2026, 12:01 PM
malcolm2 Here we are.... 75 exhaust removed. Car raised HI... Nov 5 2026, 06:38 PM
GregAmy
Here we are.... 75 exhaust removed. Car raised H... Nov 6 2026, 07:56 AM
VaccaRabite Using feeler gauges to get zero clearance is way o... Nov 6 2026, 08:13 AM
iankarr It's helpful if you use a sharpie to mark the ... Nov 6 2026, 10:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd November 2026 - 05:17 AM |
