| potomacmidget |
Mar 25 2026, 09:35 AM
I gotta have more cowbell.... ![]() ![]() Group: Members Posts: 171 Joined: 27-March 11 From: Maryland Member No.: 12,860 Region Association: North East States
Hi All -
So...I decided to do a bit of a refresh on my 71 D-jet car. Adjusted the valves, new points, (same condenser) new cap, rotor and a rebuilt throttle valve switch. New vacuum hoses everywhere, functioning AAR . Had the car on 4X jackstands to adjust the valves, and was running the car and setting the idle - had it all back together (oil bath air cleaner, new hoses). Was running great. Lowered the car (removed all 4 jackstands) and now it won't start. Nothing has physically changed. I just pulled the fuel line post fuel filter and pre-fuel pump, and fuel flowed fine. Points gap looks good, I have cranked the car with the timing light on each spark plug wire, light flashes. I don't think air is an issue, AAR wide open and boot is off throttle valve. I DON"T seem to smell fuel with all the cranking. Did I lose the prime on my fuel pump? I have an original 3 port type installed, all new gas lines as of last March. Car was running great on jackstands, I am befuddled. Any advice appreciated! thanks, Reg |
| potomacmidget |
Nov 27 2026, 05:45 PM
All - after 8 months of abandonment I got motivated to solve the issue. I pulled the distributor and checked the points, reinstalled. Car fired up. I’m thinking that perhaps I previously pulled the distributor when piston 1 displayed what I thought was TDC compression stroke, but maybe it was the exhaust stroke? Maybe too many hours hanging my body in to see the timing marks and I got confused. Glad it’s running and idling well, but I found my newly installed (prior year) brake master cylinder is leaking. Ugh, that was like the worst job ever. So I guess I get to attack that project again. Regardless I appreciate all the help and information on this site. Just re-uped my subscription. Hope everyone had a great Thanksgiving.
potomacmidget Car won't start - I seem to have spark and air Mar 25 2026, 09:35 AM
emerygt350 I would check the fuel pressure, not smelling some... Mar 25 2026, 09:45 AM
emerygt350 I would check the fuel pressure, not smelling some... Mar 25 2026, 09:46 AM
potomacmidget
I would check the fuel pressure, not smelling som... Mar 25 2026, 10:22 AM
Front yard mechanic Your car was just longing to get back on jack stan... Nov 27 2026, 06:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th November 2026 - 01:34 AM |
