will this work for me?, Distributor parts check |
Natedog |
Feb 17 2005, 10:16 AM
Member Group: Members Posts: 107 Joined: 20-October 03 From: Fort Collins, CO Member No.: 1,265 |
Hello!
Will this distributor work better than a Bosch 009 in a 2.0 914 running dual Weber 44 IDFs with a mild cam? Bosch # 0231 176 044 VW # 043 905 205H A friend pulled it from a 914 that was runnig some sort of Pinto Progressive carb set up??? And do I REALLY REALLY need to lose the 009 dizzy? Thanks in advance for your help! Cheers, Nate |
Natedog |
Feb 17 2005, 11:35 AM
Thanks SLITS! I agree that the RPM problem is more likely caused by the carbs. I need to dial them in! Do you know if any good directions for tuning a Weber 44 IDF?
But I'm still wondering if I should change out the dizzy and if that other one will be better than the 009. Cheers Nate |
Lo-Fi Version | Time is now: 1st June 2024 - 12:20 PM |
