Main bearing pins, do you got em?! |
-JR- |
Feb 17 2005, 11:58 PM
Life goes faster at 150MPH Group: Members Posts: 276 Joined: 12-May 04 From: Victoria BC Canada Member No.: 2,055 |
I'm assembling my engine and it seems that the first and third main bearings never had locating pins to keep them from spinning.
It seems only number 2 has got locating pins on either half of the case. Should 1 and 3 circular bearings have locating pins? Anyone? Thanks! |
-JR- |
Feb 18 2005, 02:28 AM
Nope, because on the full circle bearings there is only one pin used as opposed to the #2 main bearing where there are two physical halfs, so there are two pins in that case.
So either the pins dropped out somewhere when I broke it down, which I was very careful to take notes or they were not installed OR I had the case halfs run through a high temp parts washer which I suppose it's possible that the case heated up enough to drop the pins out. At any rate I need to get my hands on two of them before I can assemble the case. |
Lo-Fi Version | Time is now: 8th June 2024 - 12:53 PM |
