Hammy |
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,827 Joined: 20-October 04 From: Columbia, CA./ Tuolumne Member No.: 2,978 Region Association: Northern California ![]() |
Well we just got the 914 out of the shop and running right (When it started).
So I pull up in the driveway after driving my step mom around, showing her how good it finally runs, and I kill the engine going up the driveway (yes.. still learning the clutch) So I go start it up again, and I get nothing. Turn the key all the way and you can hear the fuel pump running, but nothing else goes. This happened before, but our *old* mechanic did some sort of start wiring 'relay' I believe he called it. Well now that seems to be a temporary fix 'cause it still won't start a day later. What gives? (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,443 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
There actually was a FACTORY service bulletin that instructed technicians to add a relay to the starter circuit to fix a hot start condition. There is a factory kit for this. If here is a relay there, its not necessarly a hack. The problem that happens with the hot start is that the solenoid gets hot and will not engage. There is not enough pull in voltage to the start terminal on the solenoid. By adding the relay, you shorten the path from the battery to the start terminal on the solenoid. This lowers the voltage loss in the circuit and allows the solenoid to engage even when the solenoid is hot. It has the bonus of reducing the voltage to the ignition switch, therefore extending it's life. |
Lo-Fi Version | Time is now: 11th July 2025 - 04:16 PM |
