How To Remove The Rear Shock Bolt?, The One On The Trailing Arm |
Spoke |
Feb 22 2005, 06:40 PM
Jerry Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The nut comes off ok but the driver side rear shock bolt on the trailing arm is rusted solid and I can't get it off. Tried some heat, liquid wrench, hammer+drift (made the biggest impression on my hand when I missed...), and a pipe wrench. The pipe wrench sorta rounded the head a bit, but no movement? How do I remove this?
I was going to remove the trailing arm (with shock attached) and see if my local machine shop can press it off. Not sure if they can or it would damage the trailing arm. Also thought about grinding off the head, removing the shock, then taking it to the machine shop for pressing. HELP!! (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) Thanks, Spoke |
Mueller |
Feb 22 2005, 08:25 PM
another decent thread penetrant is PB Blaster..you should be able to find something local that comes in a spray can. the trailing arms can take quite a bit of abuse...can you take a picture of the offending parts??? |
Lo-Fi Version | Time is now: 17th June 2024 - 01:17 PM |
