> Comments on a '76 2.0L i found, To buy or not to buy? (long)
9144me
post Feb 22 2005, 07:16 PM
PICS TAKEN DOWN, MY APOLOGY.
Info that was provided to me ahead of time:
Repainted in the last ten years, a pretty good job overall but some less than perfect spots.
The car has basically no rust. Any spots it has are very minor surface issues. No bubbling or structural issues. Jack it up and the door gaps don't change. I have known the car for 10 years and owned it for 5. It has probably been garage kept its whole life. Was undercoated (ziebart or something like it) when new.
The engine is a 2.0. It has the stock FI system and 96mm pistons. The heads have been replaced with '73 heads completely rebuilt with all new stock valves(sodium exhaust) in 2000. It has very minimal leaks. I tracked it one weekend and have autocrossed it a half dozen times. It is a good 914 for the track. I have lowered and aligned it and am halfway thru a brake upgrade. The front has BMW calipers, now the proportioning valve should get replaced and the old front brakes put on the back.
Upgraded parts:
turbo tie rod ends and rack spacers
new front rotors, pads, wheel bearings
halogen headlights
KYB struts
new metal master brake pads, new rotors, wheel bearings
19mm master cylinder, bronze bushings in pedal cluster
weltmeister front a arm bushings and sway bar bushings
weltmeister shift kit
ssi heat exchangers/bursch exhaust
pertronix points eliminator/coil
140# rear springs
issues:
-window seals replaced but seal is a poor quality copy. As a result the window won't roll up with the door closed.
-trunk hinge on one side broken. Have replacement, just never put it in.
-seats slightly torn.
EXTRAS
-custom 7" wide HRE wheels with almost new Hoosier 205 tires. If you know anything about 914 stuff you know how hard it is to get a 7" wide wheel onto a 914.
-extra case with brand new counterweighted crank, rods, and bearings. Was going to build a 150 hp motor and started accumulating parts.
-set of Tenzo racing seats. Brand new, need track mods to make fit, but should be OK. They might raise the seating position though. If you are over 5'10" these might not be a good idea.
-a whole bunch of suspension, engine, body, misc spares.
-ski rack!
new rebuilt 73 heads, new guides, shaved, stock valves didn't split case, "very strong 2 liter", great torque typical 901, 1st, 2nd a little touchy, grinds a bit like most dropped tranny, new seals, ran synthetic, changed to swepco fluid little drops out of it "good track car"
Mahles are 165 series tires HRE wheels - Hoosier, almost new. "good season left on them"
3 piece aluminum wheels, center basket weave pattern silver powerd painted, polished lip.. 7" x 15" diam.
set of 1/4" spacers included for front if needed.
Fresh 5 pt harnesses
no center console. 914/6 temp/fuel gauge.
has a sandwich plate, bypass for external oil cooler fill up back of pickup truck with spares parts
After i saw the car, my comments:
No EGR or any of that emissions crap
Fairly messy engine/tranny. Has one oil leak, nothing terrible.
Tuna can, solved pickup problem.
Runs straight 30 weight motor oil. Never heard of anyone doing that, strange.
Driver side trunk hinge broken
Car had A/C, crappy job covering it up(see pics). Should cut old floor out and weld from parts car. I have a guy who can weld just about anything for free.
Those 7" wheels are damn light! Very cool.
Hole in passenger side rear wheel well. Guy said its from changing the battery tray and isn't structural. This is my biggest problem with the car.
Jacked the car up, checked door gaps, not too bad. Moved about 3mm.
The 2.0 is a solid motor, it's got some power to it, doesn't smoke.
TONS of spare parts, rain tray, motor parts, harnesses, seats, calipers, etc etc etc
My bottom line is... I can buy this car, autox it for a year without needing anything. I can also sell the seats, spare parts for motor and a few things for at least $1k. On top of that the wheels/tires are worth over $1k new. It needs to be cleaned up here and there, fix a few small things. Barely used set of Hoosiers, nice set of wheels for them, harnesses. One thing that would be top on my list would be to bring the trunks down to bare metal and POR-15 them. After that do the same to the longitudinals and a few extra areas to make sure the rust is taken care of. There are a lot of little things that need to be taken car of: oil leak, dirty engine/trans, leaky seals, trunk hinge, etc
HELP!!!!!!!! $7k solid. Guy isn't in a rush to sell it. However I can turn around and sell the seats, engine parts and extras for at least $1k.
xsboost90
post Feb 23 2005, 07:27 AM
remember, in a public forum, opinions are...just that. Opinions. Any of us could be wrong to the price someone will pay for anything. I think most of us will simply use what we've learned in our experience a car is worth. The car looks decent IMHO but definitly needs some work. That said, $7000. will get you a beat up 6 or a hella nice 2.0, at least from what ive seen. IM sinking about $5000 into my car in the last year and i would still be surprised to get $7000 when its done. But thats just an opinion. (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
9144me   Comments on a '76 2.0L i found   Feb 22 2005, 07:16 PM
nickg   or you could buy my 76 malaga red car i had shippe...   Feb 22 2005, 07:47 PM
wilchek   looks like an eastcoast car. Seems overpriced to ...   Feb 22 2005, 07:57 PM
skline   Well, it is a stock exhaust but not from that car....   Feb 22 2005, 08:00 PM
!     Feb 22 2005, 08:32 PM
Rhodes71/914     Feb 22 2005, 08:57 PM
CptTripps   Having been 'in the market' recently, and ...   Feb 22 2005, 10:04 PM
xsboost90   looking at the pics it looks to be like my car whe...   Feb 22 2005, 10:27 PM
9144me   Thanks for your opinion guys. This is the picture ...   Feb 22 2005, 11:13 PM
type47fan   Here are some shots you might use as a comparison ...   Feb 22 2005, 11:29 PM
type47fan   another. . . .   Feb 22 2005, 11:30 PM
type47fan   more. . . .   Feb 22 2005, 11:31 PM
type47fan   last. . . .   Feb 22 2005, 11:32 PM
SirAndy   http://www.914world.com/bbs2/ht...   Feb 23 2005, 12:02 AM
porschenut   The owner speaks up. Yes the front trunk AC hole ...   Feb 23 2005, 05:32 AM
xsboost90   remember, in a public forum, opinions are...just t...   Feb 23 2005, 07:27 AM
CptTripps     Feb 23 2005, 10:25 AM
Travis Neff   I don't think a set of rims makes a car worth ...   Feb 23 2005, 10:38 AM
- Lo-Fi Version Time is now: 15th July 2025 - 02:52 AM
