What do I do now? Stripped allen screw, All ideas appreciated |
Porsche Rescue |
Feb 5 2005, 04:51 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
Started to change shift bushings at trans (side shift). Discovered that the allen set screw is stripped and will not hold the 4mm wrench. It is also flush with the "cup" so I can't get vice grips on it.
Here's the best idea I can come up with: Try to drill it out. I would like to move the whole shift console to the bench for the operation. Can I remove the two nuts (drain tranny first?) and take it and the rear shift rod to the bench/drill press? Or do I have to remove the roll pin on the shift lever to get the shift console off the tranny? All help greatly appreciated. |
Cap'n Krusty |
Feb 26 2005, 05:17 PM
Pretty difficult to tack aluminum to steel, IME. The nasty coupler can be replaced with half of a 911/912 coupler. I sold some guy about 6 of 'em at the ustabedunkels swap meet, and I'm sure there are some out there in 914 land. BTW, before pulling the console, you need to BE SURE the tranny is in neutral!! As someone else said, mark the orientation of the variuos bits so you get it back together right ............. The Cap'n
Lo-Fi Version | Time is now: 8th June 2024 - 04:53 AM |
