OT- Any electricians out there? 4 car garage!!, California code if it matters. |
Andyrew |
Feb 28 2005, 10:38 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Any electricians out there that can help me with a couple house wiring questions. We're in the closing stages of building our garage add-on. My FIL is a journeyman electricain, but doesn't do Residential and therefore doesn't know the codes.
We're putting a new 200amp service outside the new garage wall that will feed the existing 125amp inside the new garage (outside the old garage). I suspect that will need to run in conduit (or should). My FIL wants to know if we can run 3 #2 wires to feed that old service. All the new wiring will come off the new 200amp service. Questions about the garage and the Laundry room wiring. How large do the holes need to be? Do we need Conduit? What is the minimum per wall? (we'll probably add more later) If I put more per wall do you think it will raise concerns of (re)doing electrical calculations? I know they all have to be GFI protected. One of my research studies states that only the first in a string needs to be GFI the others can be standard and will pop the first GFI that they all go thru. Something like this. o/ /========O========O=======O==============O Breaker GFI std outlet std outlet std outlet I think my other house was like this. Outlets in the front of the house would pop the GFI at the back Patio. Do I need to put an outlet on the front car door mini walls? I'd like to put an exterior outlet there... Any help would be appreciated. We're getting close to shelter around the Porsches. (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) Dan (already had it posted on Andrews account. Oh well.) Attached image(s) |
r_towle |
Feb 28 2005, 11:02 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I cant help you with the wire sizing issue or the conduit issue because its a local ruling to a certain extent..
On the GFI issue, in an outdoor location that you will be daisy chaining plugs, i would put in a GFI breaker, versus a plug. If the plug is outside or in damp conditions it will either corrode and pop, or pop alot more than you like. I dont trust wet location GFI plugs...they are for convenience versus the breaker... If the breaker is close by, use a breaker. Rich |
Lo-Fi Version | Time is now: 1st June 2024 - 10:11 PM |
