this close geoff, don't get jumper idea |
rhodyguy |
Jun 7 2003, 07:16 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
0 volts at 86, if i'm doing it right. does this mean the jumper gets put in between 85 and 86 and then the relay gets plugged back in? i'm stuck. as i stated yest i'd rather shovel chicken poop.
KREVIN Attached image(s) |
DNHunt |
Jun 10 2003, 08:50 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Kevin
Hold on a second. The black/purple wire in your post got me thinking. That is the tach signal and goes to the tach. The black wire goes to the fuse S9. The green wire goes to the condenser. I think I remember you saying that you put in a Compufire so the green is probably something else. Check the wiring to the Compufire I wonder if you have the wiring screwed up with that. I bet that you need to find that black wire. Dave |
Lo-Fi Version | Time is now: 11th June 2024 - 03:08 PM |
