> OT: broken hot H2O line under house, I R a plumber now I guess
Sammy
post Mar 3 2005, 09:15 PM
I noticed a couple of strange things yesterday, my hot water heater wasn't keeping up as well as it used to, and the flower bed in front of the house is flooded.
Duh, I finally put them together today, I have a broken hot water line under the slab.
It looked comical, my whole family walking around on the tile floor barefooted trying to find the warmest spot.
i have it nailed down to a 6 square foot area, I'm going to shoot it with an infra-red heat gun tomorrow to nail it down better before I start ripping up 5 year old (expensive) ceramic tile that i may or may not be able to match. I have a few squares left over from when I installed it, hopefully that will be enough.
Luckily it looks like it's in the middle of an open area and not under a cabinet or something. I figure with a little luck and an electric jack hammer I can find and fix the leak. I'm waaaay too much of a CSOB to hire a real plumber, prolly cost me more in the long run but that's who I am.
Any BTDT stories or advice before I rip into it?
Tanks.
davep
post Mar 4 2005, 04:16 PM
914 Historian
I can sympathize. We had a leak in the hot water line as well. It is caused by galvanic corrosion, so it will not be localized. You may have many small leaks, or will have. My house is slab-on-grade. The attic gets well below freezing in winter. The only solution I had was to install a small water heater under the kitchen sink. The cold line usually has no problems. For the bathroom I was able to run a new line alongside the hot water heating line. Hot water lines in the ground always fail.
Sammy   OT: broken hot H2O line under house   Mar 3 2005, 09:15 PM
spare time toys   We had this and ended up re doing the hot water pi...   Mar 3 2005, 09:22 PM
scott thacher   are you sure it is not easier to run a new line in...   Mar 3 2005, 09:25 PM
Sammy   Now there's a ray of sunshine, thanks Larry   Mar 3 2005, 09:28 PM
SLITS   It's considerably easier to go overhead and re...   Mar 3 2005, 09:31 PM
GWN7   Larry's plan makes the most sence to me. Unles...   Mar 3 2005, 09:32 PM
URY914   Yes, Yes, Yes, go overhead with a new line. If you...   Mar 4 2005, 07:45 AM
vsg914   Finding the hot spot on the floor may or may not g...   Mar 4 2005, 07:56 AM
Sammy   It is the hot water line from the heater. My guess...   Mar 4 2005, 10:05 AM
Bruce Allert   Like Curt says, just finding the hot spot isn...   Mar 4 2005, 10:55 AM
URY914   Hate to throw water on your plan, but chipping out...   Mar 4 2005, 10:56 AM
MarkV   Call American Leak Detectors. They use a stethesco...   Mar 4 2005, 12:41 PM
bondo   You should just dump in a can of radiator stop lea...   Mar 4 2005, 12:56 PM
andys   Fixing the leak may only result in another leak el...   Mar 4 2005, 02:48 PM
Lou W     Mar 4 2005, 03:30 PM
URY914   They are piped overhead because plumbers don't...   Mar 4 2005, 04:01 PM
fiid   Could you seal the pipe and hook it up to a compre...   Mar 4 2005, 04:17 PM
Sammy   My piping is copper, house was built in '69. ...   Mar 4 2005, 05:23 PM
scott thacher   while you at it i saw a tv show on plumbing and th...   Mar 4 2005, 05:32 PM
Sammy   Will do. One of the first things I did when I boug...   Mar 4 2005, 05:38 PM
Travis Neff   The welders handbook has the whitebread trick in i...   Mar 4 2005, 05:42 PM
vsg914   anyone else know the white bread trick? Yep. It d...   Mar 4 2005, 08:30 PM
andys   http://www.914world.com/bbs2/...   Mar 5 2005, 07:56 PM
markb   Congrats, Sammy!! htt...   Mar 5 2005, 08:03 PM
!   Lucky shit....go buy some LOTTO tickets...   Mar 5 2005, 08:24 PM
Lou W
  Mar 5 2005, 08:27 PM
URY914   Lucky SOB, Sammy. http://www....   Mar 5 2005, 08:44 PM
Sammy   here's the pics:   Mar 5 2005, 10:57 PM
Sammy   how do you post multiple pics in one post?   Mar 5 2005, 10:58 PM
- Lo-Fi Version Time is now: 16th July 2025 - 04:39 PM
