riddle me this batman, saga continues |
rhodyguy |
Jun 11 2003, 07:16 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
as per the haynes wiring diagram, the black/purple wirie runs from the #1(-) term on the coil to the #5 connection on the rear wire bundle on the relay panel. now then, should the #5 pin on the relay be a direct connection to ground?
kevin |
DNHunt |
Jun 11 2003, 08:12 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Kevin,
My manual shows the bl/pu wire goes to pin 5 through the 12 pin connector. Pin 5 is direct to pin 7 of the 14 pin connector and runs to the Tach. Kevin Check S9. It also looks to me like the ground path for the negative side of the coil is through the condenser or in your case the Compufire. I don't know the more I look at it the more confusing it looks. Dave |
Lo-Fi Version | Time is now: 11th June 2024 - 04:55 PM |
