> rear brake tee install pics?, anyone have any?
mightyohm
post Mar 7 2005, 02:30 AM
Anyone have any pics of rear brake tee installs? I want to see how much you have to bend the hardlines and how you did it. I have a nice ATE brake tee off a BMW 2002 that has a mounting hole in it, but I'm not sure I can bend the lines enough to mount it to the firewall where the prop valve used to be. Before I go and make a bracket or something I would like to see what others have done.
Thanks!!
PS: You can remove the prop valve with the engine in the car, it just takes a few minutes. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
mightyohm
post Mar 7 2005, 11:22 AM
Paul, I would love to see pics of your setup. Are you worried about the tee bouncing around and fatiguing the lines?
I forget who it was on PP that was talking about mounting the tee to the firewall using a 1" spacer and one of the existing prop valve threaded holes. It sounds like a great idea but I think the lines would have to be bent significantly to make it work.
- Lo-Fi Version Time is now: 19th June 2026 - 06:26 PM
