| reverie |
Mar 8 2005, 04:51 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 783 Joined: 14-March 03 Member No.: 427 Region Association: None |
John Walker's post over on Pelican asks about this.
CV joints seem to be NLA... nobody has them. Is this part cross-listed as a VW part? (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
| ArtechnikA |
Mar 8 2005, 02:08 PM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
halfshafts should be removed, cleaned, inspected, repacked, and reinstalled with new Schnorr washers and (ideally, IMO) new bolts, on a periodic basis. mostly it depends on how hard they're being called upon to work -- how many track days transmitting full power, how many AX's with body roll, how many really hot days. and the quality of the grease used. when i did a full season of track events, i repacked the CV's twice in the year. real racer guys probably have an even more aggressive inspection/repack schedule. some folks also swap them from side to side to equalize the thrust wear. CV's must have a substantial amunt of compliance axially, but when you grab the drive shaft, you should not be able to detect any rotational movement, and if you try to move the axle up-and-down or back-and-forth, there should be no movement. remove, iclean, inspect, and repack the halfshafts every couple of years and you'll see little cracks in the cages and excessive wear before it's bad enough to risk failure at speed (which you don't want to have happen especially to an inboard joint...) |
reverie CV joints for 914/4 Mar 8 2005, 04:51 AM
ArtechnikA yes, they're NLA.
no, they're not availabl... Mar 8 2005, 07:20 AM
Yoei66 I blew a CV joint on the passanger side a month ag... Mar 8 2005, 08:29 AM
rdauenhauer So how do you determine if the CVs on your now 30 ... Mar 8 2005, 11:53 AM
Bleyseng Clunking, noise, grinding, excessive slop in the C... Mar 8 2005, 12:53 PM
914GT This VW CV joint part # 113501331 is close to the ... Mar 8 2005, 01:06 PM
rdauenhauer <... Mar 8 2005, 01:58 PM
ArtechnikA Mar 8 2005, 03:08 PM
James Adams ![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 01:10 PM |
