> Engine shelf, Removal
spunone
post Mar 9 2005, 08:36 AM
Ok half the engine shelf is rusted out whats the besy way to remove the rest of it grinding wheel saw or what .I have the new one just don't want to make a bigger mess than ness.Another ? what do you use to coat the floors with after I've removed all the sealer crap and wire brushed the rust out? Thanks again in advance
riverman
post Mar 9 2005, 08:48 AM
Learn As I Go
The best way (leaves the least damage) is to remove the paint so you can see the spot welds and then drill or cut out the spot welds. Once all the spot welds are removed the shelf should just fall off. This method can be a PITA though because there are alot of spot weld.
If your not overly concerned with the after appearance, you can cut off the shelf with a cut-off wheel or sawzall and then grind the welded on lip down flush with a grinder. Using this method, you will end up with grinder marks on whatever the shelf was attached to, but it will be faster.
- Lo-Fi Version Time is now: 3rd March 2026 - 02:38 PM
