| freezing14 |
Mar 9 2005, 09:36 AM
freezing14 ![]() ![]() Group: Members Posts: 435 Joined: 21-June 04 From: brockville , Ontario, Canada Member No.: 2,233 |
I am getting to the point whre the windsheild is going in,, called around to some glass shop and they think they are wizzard of some sort because of the price they charge and the BS they say to get your business,,, so i decided to do it myself using the butyl tape, i found a place who sell it but they have a couple of size 3/8, 5/16 square round etc,, what is the best one to use
thanks guys (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) |
| Steve Thacker |
Mar 9 2005, 11:29 AM
UMMMPH Yea Baby Yea ! UMMMPH ![]() ![]() ![]() Group: Members Posts: 1,089 Joined: 8-January 03 From: Pickerington, Ohio Member No.: 113 Region Association: Upper MidWest |
The urethane installation was a no brainer in IMHO. The installer used a special glass primer on a 1/2 inch portion of the glass, let it dry. Then he pulled out a tube and stuck it in a chaulking gun and then proceeded to apply it directly to the inside of the new windshield over that same 1/2 inch black primer. He had already cleaned up the inside of metal on the frame and applied the same primer. He used two suction cups and popped in the windshield. Tapped it slightly in and then squared it away in the metal frame. Then used a razorblade to clean off the excess inside. To me it seemed much simpler than screwing with Butyl and it won't come loose via extreme heat or cold.
freezing14 windsheild installation Mar 9 2005, 09:36 AM
riverman When you find out and actually put your windsheild... Mar 9 2005, 09:39 AM
aircooledboy If you have removed all the old seal from the fram... Mar 9 2005, 09:41 AM
Steve Thacker Please do not use Butyl tape to install your winds... Mar 9 2005, 10:54 AM
aircooledboy Well, thats partly true. A proper buytl installati... Mar 9 2005, 11:17 AM
freezing14 ok and what is that primer for ,, i urethane the b... Mar 9 2005, 02:41 PM
McMark I'm in the Butyl camp as well. Worked fine fo... Mar 9 2005, 02:46 PM
davep The original factory install used a heated wire ca... Mar 9 2005, 02:56 PM
vsg914 I vote on the side of urethane. I 've installe... Mar 9 2005, 03:04 PM
Steve Thacker ![]() ![]() |
Lo-Fi Version | Time is now: 7th October 2026 - 11:06 PM |
