Lug Bolts, Gimme the lowdown |
TravisNeff |
Mar 9 2005, 04:08 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
I have a question regarding lug bolts.
How much available thread engagement do you need after the bolt passes throught back of the wheel mounting surface? I have a set on my western wheels that is a lot longer, the shank has about 1/2 or so of non threaded surface, flat face washers on them. The others that I have on my enkies could be stock for ?? steel wheels, alloys? it's a ball seat, fully threaded and protrudes out of the back of the wheel about 1/2 or so. |
jwalters |
Mar 9 2005, 06:46 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
Depending on the thickness of your wheel hub I would say use the standard bolts--they go in pretty far--u may run into trouble with the bolt hitting badly rusted theads from nothing touching it in years--and then when you go to remove them for any reason, they may twist off in the hub-- |
Lo-Fi Version | Time is now: 10th June 2024 - 06:49 AM |
