Fuel leak, Fuel pump location? |
#1RAGE |
Jun 12 2003, 12:30 PM
Member Group: Members Posts: 139 Joined: 7-May 03 From: Saskatoon, SK, Canada Member No.: 664 |
Hi,
I'm a fairly new 914 owner and a couple of weeks ago a noticed a strong gas smell but I didn't really investigate it until today. I pulled out on to the driveway and looked underneath the car and found a fairly large wet spot under the gas tank. When the car is running I can see a steady stream of gas coming out of the wet spot going right to the ground. So it seems to leak badly when it is running and very little or not at all when the engine is off. I'm thinking it must be the fuel pump or a loose connection somewhere near the bottom of the tank. I have a Haynes manual that came with the car and I can't tell where it is located by looking at the pictures and it does not say where either. So where is the fuel pump? (IMG:style_emoticons/default/confused24.gif) I'd like to investigate the problem myself in case it is something simple to fix, if not I will take it to the mechanic to get it fixed. My car is a 1974 1.8L USA model. Thanks |
Brad Roberts |
Jun 12 2003, 12:34 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Unless somebody moved your fuel pump to the front.. the pump will be just in front of the right rear tire right next to the frame rail.
I'm betting your fuel lines are rotted as they come off the tank. Let me dig out some pics.. B |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:42 PM |
