Camshaft Assistance and Translation |
Mockmaw |
Jun 12 2003, 09:41 PM
Member Group: Members Posts: 163 Joined: 18-March 03 From: Berkeley/San Diego, CA Member No.: 438 |
The camshaft is the last component of my rebuild that I haven't decided upon yet. I'm trying to learn what I can about them so I can make an intelligent purchasing decision. Yes, I know this is a broad topic..
I don't understand the relationship between duration and lift.. what running aspects are changed as a result of increased duration? What aspects are changed as a result of increased lift? At what lift and/or duration should I worry about longevity issues? There are so many numbers out there and the descriptions that go with each camshaft seem too vague. I can stare at the webcam page all day and still not know how different an 86 will be from an 86a or 86b.. or 494, etc etc etc. Can anyone help me or point me towards some resources that will help me translate these numbers a little better? Thanks! |
Mueller |
Jun 12 2003, 11:22 PM
Depending on the valve train geometry, the higher lift cam might not work with stock springs before they would bind (compress and have each coil touch)
or piston to valve clearance might be too close and the higher lift valve could hit the piston top unless the piston is machined with a relief. The high lift/short duration cam is ideal for a turbo motor since the incomming charge could end up going out the exhaust if the duration is too long (overlap) the longer duration cam will have a weaker vacuum signal but it will be "gentler" on the valve train since it does not have to ramp up so fast to attain the higher lift did that help or confuse you more (IMG:style_emoticons/default/barf.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 04:01 AM |
