factory oil cooler, can you install it while its in the car |
bernbomb914 |
Mar 15 2005, 07:30 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
have to change the oil cooler. can it be done in the car without removing the motor
Bernie |
ClayPerrine |
Mar 15 2005, 09:48 PM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Yes, it CAN be done with the engine in the car!!!! (And why does everyone not believe me when I say this???) I did it that way 6 times. It worked every time. Just follow the procedure for replacing the seals, and then unscrew the 2 long studs. The cooler will fall out. When you go to put it back, just put the studs in the cooler before trying to put it in. Then install the seals like the article outlines. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:05 AM |
