Engine is slooowly coming together, Here's the shortblock |
Qarl |
Jun 13 2003, 03:31 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Finally remembered to bring the camera to take a picture of the shortblock. or the mid-block. It's not quite a long block yet.
Cylinder heads are getting new studs, valves, and valve springs. Cams are on order. Nice and shiny 98mm J&E Pistons and cylinders. Regards, Attached image(s) |
Qarl |
Jun 13 2003, 04:54 PM
I didn't mean to mislead people. I'm not building the engine.
Harro Zitza from Zotz Racing here in Winter Park, Florida is building it. He's in his late sixties maybe 70 or so. Been building and racing Porsches for 40+ years. These are the specs. 1979 3.0L SC core - disassembled - magnafluxed, polished, crank and rods, blah blah Early SC heads with the larger intakes and single plugs - new valves, springs, guides, etc. 98mm J&E Pistons & Cylinders 9.8:1 CR optimized for carbs with deeper valve recesses Elgin Modified S cams (not quite as peaky, but the displacement will help smoothe out some of the peakiness anyways) Electromotive Distributorless Ignition New Oil Cooler 3.6L Carrera Oil Pump 46mm Weber IDA carbs Kennedy Performance 9" Clutch Package flywheel, and Stage II pressure plate... It will be a 3.2L short stroke when finished. Should put out 250-260 ponies.... (IMG:style_emoticons/default/MDB2.gif) Moowaahahaaaa |
Lo-Fi Version | Time is now: 5th June 2024 - 02:14 AM |
