ok, so I got a little of the bad stuff, rust, that is... |
tat2dphreak |
Mar 16 2005, 07:24 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
it's not much, and it's mostly surface rust on the long, the jack post brace is worse... but the long is solid...
I'm thinking: grind/brush off all the rust and then ospho(or metal ready) and por-15 is that good enough for solid metal? or should I put a plate over it after that as an extra brace? let me know what you think... btw, when I took the rocker off, no less than a pound of DIRT fell out!! I know to clean this spot, but evidently the last guy forgot (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Attached image(s) |
rhodyguy |
Mar 17 2005, 09:52 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,098 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
those stupid little drain holes on the bottom of the jack reciever plate are useless. have a light touch when you're wire wheeling the rust off. hopefully you won't go through the existing metal. i used Mar-hyde to treat the rust on my recent trunk work, primer and paint. it's very easy to work with and a damn sight cheaper that the por-15.
k |
Lo-Fi Version | Time is now: 17th June 2024 - 10:51 AM |
