tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
it's not much, and it's mostly surface rust on the long, the jack post brace is worse... but the long is solid...
I'm thinking: grind/brush off all the rust and then ospho(or metal ready) and por-15 is that good enough for solid metal? or should I put a plate over it after that as an extra brace? let me know what you think... btw, when I took the rocker off, no less than a pound of DIRT fell out!! I know to clean this spot, but evidently the last guy forgot (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Attached image(s) ![]() |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,098 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
i carry a stock jack for looks and around town. over 75 miles and i lug around the small floor jack. i'd probably pull the car over and hitch home to get the floor jack if i got a flat. call around to some auto body repair supply stores. they SHOULD have some. "cheap" was relative. in a world of $6 per pack for smokes, $3 coffees, and $6 beers, it is "cheap" to me. a quart ran me about $25 but you don't use much at all when you apply it. foam brushes, roller, or spray.
k |
Lo-Fi Version | Time is now: 17th June 2024 - 10:52 AM |
