LukeD |
Member ![]() ![]() Group: Members Posts: 254 Joined: 14-November 04 From: Atascadero, CA Member No.: 3,117 Region Association: None ![]() |
I pulled off the front of my engine today to clean the crap out of everything. Before I pulled the fan and the large cooling duct piece I turned the fan until the timing mark lined up with the notch. After pulling the fan I noticed I have 2 marks a few inches apart, which one is TDC? Also, after lining them up I pulled the cap and noticed that the rotor was pointing to the #4 spot on the cap? This engine has definately been pulled apart, so is this right? Does the fan only bolt on one way? (i forgot to check) I am planning on adjusting the valves with the motor out, just want to make sure everything is setup the way it should be.
Luke D |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Make absoluty sure your on TDC for #1 (both valves closed), and index drive gear to that position. There is a washer on the bottom of the gear that you are not susposed to drop thru the hole in bottom of the shaft, but I just can't see how that 13 mm washer is gonna fit thru that 8mm hole.
Lo-Fi Version | Time is now: 17th June 2024 - 11:32 AM |
